So, last weeks episode ended with me with my head hanging low and the contemplation that hard drugs and hard alcohol could possibly act as a substitute for my obsession to get into multicopters.
(See http://diydrones.com/forum/topics/things-that-go-up-tears)
That was the past... this weekend I finished replacing my frame with an XAircraft Hexa. For those unfamiliar with my saga, my jDrones Hexa ended in a pile of twisted metal last Monday night. Still in a sense of shock, I ordered the XAircraft Hexa Carbon Fiber and Plastic frame from Taiwan, which I recieved Wednesday! The new frame is about 3" diameter smaller that the old one, but solidly built. I never wieghed the jDrones with all of the electronics and legs made out of buckets, but this one feels a little heavier. The 10" blades come within .5" of each other, so there will be no 12" props on this one. I also woried about the turbulance caused by them being so close.
By Saturday, the hexa was back in the air! I flew it with standard default 2.3 setting and it seems to fly fine. I haven't yet determined the nuances that I should be tweeking, so it can't be all that bad. took it to a local school (site of the last disaster) and flew it in stabilize, Loiter and RTL. Everything worked out spectacular, but I may want to play around with Loiter as the radius is about 3 meters.
I was a very nervous after the last crash that all of the work I put in would end up with me having to get a box to gather up the pieces when this one crashes. But I am claiming success!
Here's some pics of the thing I am calling "Black Widow". Partially becsause its black and looks like a spider, and partially because it scares the hell out of me.
Permalink Reply by Dusty Starbucks on February 16, 2012 at 12:01am
Permalink Reply by James on February 15, 2012 at 5:22pm does look very good and i particularly like the lighting, where did you get that forward facing set of white leds?
the landing looks nice too, is that part of the frame kit?
james
Permalink Reply by Dusty Starbucks on February 15, 2012 at 11:59pm
Permalink Reply by bret on February 16, 2012 at 6:27pm Any worry about the heat under the dome, or is there enough airflow from underneath to keep things cool enough? Might be a dumb question, haven't built one yet.
Permalink Reply by Dusty Starbucks on February 17, 2012 at 12:01am Good question. I don't think it's an issue, there isn't that much heat generated inside, most power dissapation is at the motor, or at least I would hope (efficient design and all that). I'll try to find out. i would expect the ESC would be the hottest. I can put a peak hold temp sensor on one to find out how hot it gets or just float it in the dome for ambient temp. It's certainly not a concern with winter temps, but I'll have to check that.
Permalink Reply by Blaine Hoyt on March 5, 2012 at 4:24pm I went through a very similar situation as you, and am currently replacing my jdrones hexa with this bad boy. Already very happy, and this is only after 10 minutes of assembly (it seems very sturdy)! Question though, how/where did you attach the hexa-pcb to the frame? A little confused on the best method for doing so...
Thanks,
Blaine
Permalink Reply by Dusty Starbucks on March 6, 2012 at 10:16pm I had to drill four holes in it to line it up. I don't have a picture, but you just don't want to skinny up a current carrying trace. I believe the holes lined up pretty well so as not to do that. You will find the placement of the four hole on any of the plates (these are the holes where the thing that looks like a battery mount attaches). You could use that battery mount plate as a template for the holes required. Then use some of your polycarbonate hex standoffs to attach it. If that is clear enough, cool. If not, I could go take some pics without taking it apart (not ideal pics :)
I believe it had to be mounted upside down in my case, which made getting the right control wires to the right motor a little disorientating. That may not be the case for you, depending on how you soldered it.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.720 members
24 members
203 members
1355 members
207 members
Powered by
