I had really hard mag_field interferences compass in one of my custom copters (see Tridge analysis done in this other topic)
See the mag_field during a normal flight:
The harness arrangement was done randomically inside the two main plates .In particular both red and black lines were independent (not good for mag_field!):
So, I decided to re-route the powerlines by substituting the old harness by independent highly twisted lines for each of the ESC´s starting from the battery. I´ve shortened also the battery cables to the maximum, and also twisted them a bit.
So the result is awesom: It complitely solved the problem (see second Image of a similar flight).
I hope this help others to solve in the root the eventual interference compass problems: lets "twist and shout"!
Angel
Clarification:
What I want to say for "independent highly twisted lines" is the following:
From the battery I´ve created four independent lines black-red (- & +) driven to each of the ESC´s. Each pair of +/-  cables are highly twisted in order to cancel its own magnetic field by its own. This is done for each of the four pairs of +/- cables .
Great write up! Thanks for sharing this information. I almost wonder if this should be a blog post so more people have eyes on it.... Its good information for everyone.
Thanks again!
Great stuff afternan !
Did it solve yaw problems you were having ? (if not, what symptoms did it solve ?)
The thing that still bother me is this : with 2.046 till 2.0.55 I didn't have any yaw problems and my wiring was the same as it is now...
Power to my hexa motors is done in a starburst form *.  A central feedline from the battery is split into 6 branches heading into each arm
That's a great result Angel!
Very cool!  EMI issues are always a pain. Care to post a pictures with twisted pair harness?
Nice one Angel!
He was the one who flew avoid, but unfortunately it is inevitable ... "come on let's twist again"... :P
Extensive flight test results with new hardware setup
The goal is try to get the best offsets for the better flight. Also to compare the three method we have:
  1. Using MP / hand rotation , motors off
  2. Using MP / TLOG offline calibration
  3. Compass_learn by Tridge
Method 1):
hand rotating (no motors) -43, 30, 25   repeteated again   -30,31,17
Method 2):
Using MP / TLOG offline calibration. I´ve got three long fly records (see attached TLOGs)
TLOG
Thro>10%
Thro>20%
Thro>30%
2012-04-02 20-17-35
-21 31 76
-21 31 76
-21 31 76
2012-04-02 19-54-08
-14 34 64
-14 34 64
-14 35 65
2012-04-02 19-00-45
-17 36 89
-17 36 89
-17 36 89
2012-04-02 20-17-35
2012-04-02 19-54-08
2012-04-02 19-00-45
Method 3):
Compass Learn:
Outdoor flight:
After 2 min flight                   -2,40,-4
After 5 min more                   -19,39,-14
After 10 min more                 -18,52,-11
After 15 min                           -16, 16, -95
CONCLUSSIONS
  • Compass_learn gives very different values for "mz_off", but similar values for "mx_off" and "my_off".
  • Method 1 (hand rotating, no motors gives also similar values for mx, my but not for mz offsets.
  • So we can consider mx_off = 21 , my_off = 31 as good values since in all three methods are similar.
  • For mz_off I rely in second method, that is not so far than first method: let say mz_off = 65
  • A flight with this values confirms that they are good  (see TLOG graph 2012-04-02 20-17-35)
Looking fordward your comments on this results to try to commint on one method for today until we get another.
Hi Angel,
Thanks for the tests! The 19-54-08 log is very interesting as it shows the learning algorithm doing quite poorly on the Z axis. The Z axis is always the hardest to learn, but this is worse than I expected. I'll see if I can use this log to work out why.
One thing to keep in mind is that what we're aiming for is to get a good heading. So graphing the heading produced with the different offsets gives you some idea of whether the differences matter. Here is a graph of the heading you would have seen with the learned offsets versus the tlog throttle 30 offsets for the 19-54-08 log
there are differences, but they are not huge. That is because the Z offset tends not to change the heading much in level flight (which is also why it is hard to learn!).
Still, I would like to improve the algorithm. That Z offset is further off than I'd like it to be.
Cheers, Tridge
Hi all,
prior to using 2.5.3 I ha no problems with yaw.
With 2.5.3 yaw would have a will of it's own, wandering about 25º to each side; I believe it must be some kind of process that now is more sensitive to mag interference,
So I followed afernan's advice, high-twisted all power lines and moved the mag a bit further away.
Tested it today, and yaw is back to rock solid.
Thanks! great tip!
That's very nice Dani !   Unfortunately twisting powerlines would require a complete dismantling and rewiring of my copter, which I really don't see me doing.
Surely we can't expect all users with yaw problems to rewire their copter ?  It worked fine before (2.0.49) so we should be able to get it working fine again.
Dying to see some photos! I have been having some issues regarding Random Yaw on my X8.  Would twisting wire always be a good practice in main wiring for future reference? I haven't really studied my logs yet, too busy reppairing and balancing props.  TIA :)
