I am trying to test my APMega and have a problem understanding how to get code from the repository. I gather the Zipped up file of libraries is out of date and I should be using the latest from the repository. I look in https://code.google.com/p/arducopter/source/browse/#svn/trunk/libra... but am unsure how to download the files and find many of the file names are just html links.
Can someone explain how to get the latest library files easily from the reporsitory - I hear about needing Tortoise or a similar svn tool but this is all over my very small head as are subversion, trunks, branches etc? I have tried to read up about it all but nothing made much sense to a simple user like me.
Peter
We don't recommend that people use the code in the SVN repository at this point. It's changing daily and often has not been tested--it's really just for the developers. Once we test a build properly, we move it to the zip file.
We're in the alpha testing phase, so please be patient. We should be in beta within the month.
Do you know if the ArdupilotMega APM_ADC_test prog works correctly as I am getting values of about 1595 for the temp and around 2000 for the rest of the sensors even when stationary? I read a post from Julio that I should be downlaoding the latest version of the libraries.
Peter
I'm on a plane now but I can create a new zip file of the latest libraries when I land tonight.
That would be great, thanks Chris
Hi Peter,
Not sure if it helps but this is what I get:
2038,2033,2471,1669,1673,1675,1683,2869
Make sure to use the latest version of the test program. I have seen at least two
(I think the right one has baud rate 115200)
Yes Andre that looks about the sort of numbers I got. I couldn't understand why I got those numbers when the manual says
"When your APM is on a table, the Z accel reading will be high, while the X and Y are near zero. That's because it's measuring the force of gravity, which is an acceleration (9.8 m/s^2). When you rotate the APM sideways or vertical, you'll see that reading shift to the X or Y, depending on which one is now measuring"down"."
So I was expecting some much lower numbers.
Peter
Peter, that's my fault. I was referring to the actual gravity readings after corrections. I'd forgotten about the ADC test, which is just analog voltages. I'll correct the manual.
If you were to tag the repo once you're done testing and ready to cut a zipfile, those of us following along at home would have the best of both worlds. (I see that you're currently not tagging...)
