Comm problems seem to be drawn to me. This time it appears to be an issue with comm between the GPS and the APM. I reliably get a solid blue light on the MediaTek, indicating GPS lock I believe, but the red LED (C) on the APM doesn't light up. I'm running the ArduPiratesNG release 458 (latest one available for download on their wiki). Best I can tell, there's no way to know what firmware is loaded on the GPS, but I see the same behavior if I configure for 1.4 or 1.6.
My first thought was that it's a GPS firmware problem and I need to reload the firmware as instructed on the wiki (gotta buy a friggin' FTDI cable, ARGH). But then I saw this post, which led me to believe that there might be some versions of the code floating around where LED C isn't functioning correctly???
I've also read multiple insinuations that there's some way to test the GPS via CLI, but I can't find instructions on how to do so for the life of me. Then I found this post on RCG and ran knuckles' code, whose result was a bunch of gibberish on the serial monitor. Here's a sample:
Ö f¡ÎÐÝ âá´ûùz_M × ~±§ÐÝ âá´ûùz_M Ø ©"ÐÝ âß´ûùz_M Ù ~¢ÝÐÝ âß´ûùz_M Ú ÐÝ âß´ûùz_M Û ÐÝ âß´ûùz_M zÜ fz<ÐÝ âÞ´ûùz_M tÝ fuÐÝ âÞ´ûùz_M nÞ fq
And as a longshot, per this post, I've hit the reset button after getting a lock while configured for both 1.4 and 1.6 ... with no luck.
Any ideas?
... I think my head is going to explode :) ...
I am having a similar issue.....facts
1.bought MT3329 smt module from diydrones last week
2.I put it on the board and used sparkfun level shifter to connect to arduino pins, and left enable floating.
3.apply 3.3volts and light blinks...it has been blinking for about 8 hours now....no lock
3.when I try to run test code from link on product page, it does not work....It was not designed for 2560 board so I changed the if defs to allow it, and it still locks up after "GPS MTK library test"
4. So then I tired serial pass through example in arduino ide.....I get a bunch of binary characters like shown above
4.I ran the pde that is attached in this post and I got the following output.
Setting to NMEA modeSetting to real slow modeRequesting relase numberRequesting relase number<10><FFFFFFEC><FFFFFF90><FFFFFF92><FFFFFF90><FFFFFF90><FFFFFF80>p<C><C><C>l<FFFFFF8F><1C><FFFFFFE0><FFFFFF8C>b<C><FFFFFF8F><FFFFFF93><C>bcbbc<C>b<C>ccb<FFFFFF8E>p<C>c<FFFFFF8E>p<C>b<12><FFFFFF90><FFFFFFEC><FFFFFF8E><E>l<10><FFFFFFEC><FFFFFF90><FFFFFF92><FFFFFF90>l<2><FFFFFF82>b<FFFFFF80>p<FFFFFFFC>pp<C>bbbcbbccbbccb<FFFFFFE2>lll<FFFFFF90><E>l<10><FFFFFFEC><FFFFFF90><12>lsr<FFFFFF83>c<C><C>l<FFFFFF8E><FFFFFF8E><C><FFFFFF8C>b<C><FFFFFF8F>sp<FFFFFF8C><FFFFFF93>ccbbc<FFFFFF8C>b<FFFFFFFC><FFFFFF80><C>c<FFFFFF8C>b<C><C>c<FFFFFF8C><FFFFFF8F>l<C><C><C>cRequesting relase numberRequesting relase number<10><FFFFFFEC><FFFFFF90><FFFFFF93><FFFFFF90><FFFFFF90><FFFFFF80>p<C><C><C>l<FFFFFF8E><1C><FFFFFFE3><FFFFFF8C>c<C><FFFFFF8E><FFFFFF93><C>bcbbc<C>b<C>cRequesting relase numbercb<FFFFFF8E>p<C>c<FFFFFF8E>p<C>c<12><FFFFFF90><FFFFFF8C><FFFFFF8F><E>l<10><FFFFFFEC><FFFFFF90><FFFFFF92><FFFFFF90>l<3><FFFFFF83>c<FFFFFF80>p<FFFFFFFC><FFFFFF82><C>bbccbbccbbccbb<FFFFFFE3>lll<FFFFFF90><E>l<10><FFFFFFEC><FFFFFF90><FFFFFF92><FFFFFF90>l<FFFFFF9C><FFFFFF82>bppl<C><FFFFFFE2><FFFFFF80><C><FFFFFF8C>c<FFFFFF8E>|rl<10><FFFFFFEC><FFFFFF90><12>lrr<FFFFFF83>c<C><FFFFFFFC><FFFFFF80>l<FFFFFF8E><1C><FFFFFFE2><FFFFFF8C>b<C><FFFFFF8F>sp<FFFFFF8C><FFFFFF93>ccbbc<FFFFFFFC>|<C><C><C>c<FFFFFF8C>b<C><C>c<FFFFFF8C><FFFFFF8F>l<C><C><C><FFFFFFE3>p<C>cl<12><FFFFFF90><FFFFFFEC>Requesting relase numberRequesting relase number<10><FFFFFFEC><FFFFFF90><FFFFFF93><FFFFFF90><FFFFFF90><FFFFFF80>p<C><C><C>l<FFFFFF8E><FFFFFF8E><FFFFFF8C>c<C><FFFFFF8F><FFFFFF92><C>bbcbb<C>c<C>bbc<FFFFFF8F>p<C>b<FFFFFF8F>p<C>b<13><FFFFFF90><C>l`<2><10><FFFFFFEC><FFFFFF90><FFFFFF93><FFFFFF90>l<2><FFFFFF82>b<FFFFFF80>p<FFFFFFFC>pp<C>bbbcbbccbbccb<FFFFFFE2>lll<FFFFFF90><E>l<10><FFFFFFEC><FFFFFF90><12>lsr<FFFFFF83>c<C><C>l<FFFFFF8E><FFFFFF90><C><FFFFFF8C>b<C><FFFFFF8F>sp<FFFFFF8C><FFFFFF93>ccbbc<FFFFFF8C>b<FFFFFFFC><FFFFFF80><C>c<FFFFFF8C>b<C><C>b<FFFFFF8C><FFFFFF8F>l<C><C><C>cbRequesting relase number
I am thinking the level shifter might not be working properly or something. But I don't know why it has not gotten a gps lock yet. Any help is appreciated thanks!
I am running the RC2 coding for my Quad.
I have the Solid blue led on the mediatek GPS but the Red led on APM will be kept blinking. Does it meant the APM didnt recognise the GPS lock from GPS?
Thanks for the gps - test - code:
It doesn't work:
I guess this means my gps doesn't work.
I am.
What setting in the cli do I need to choose so I see the gps status?
Hey Martint,
you mean the baud rate while in cli: max I guess 115000 I can't look right now.
I don't have a ftdi cable yet, so I can't check the gps
I used the online configurator to setup gps to v1.6 (in hope this one is up to date)
I got it from Fahpah.com:
Here are some pictures:
NO,
I don't think so.
At first I tried to build my own FTDI cable and the first thing I did was connecting +5V and GND to the module and the solid blue led went on.
(+5V was written on the module)
...please don't tell me I've killed my gps
I don't think the solid blue led of the mediatek gps module is a sign for gps lock.
As soon as I switch on my copter the blue led is solid blue. And I am inside...never went outside, yet.
@Ariley
re. I reliably get a solid blue light on the MediaTek, indicating GPS lock I believe
Correct.
re. Best I can tell, there's no way to know what firmware is loaded on the GPS
Incorrect.
Read this thread, all the way to at least page 3. (Today) I show a method to query the GPS.
http://www.diydrones.com/forum/topics/mediatek-gps-up-to-date
re. ran knuckles' code, whose result was a bunch of gibberish on the serial monitor. Here's a sample:
The GPS may be in binary mode. Or the baud rate on your computer may be wrong. Or the cable could be Borked. Or when programming of the APM you may have selected a board with a different clock rate, so the baude rate of the APM isn't what it is supposed to be.
If the CLI doesn't communicate with you, upload to the APM a simple "Hello World" sketch to see if you can Serial.print() back to your computer or if that is messed up.
