Hello
I'm newbie arduino.
my first targe is to control servo and ESC.
I succeed working servo by using ArduPilotMega_dancing tutorial.
but i want to work servo by using servo library (arduino example ... sweep? below example )
unfortunately, this code is not working.
so.. i guess the problem.
maybe pin number is wrong?
or... ardupilot cannot use servo library?
and..
can you tell me how can control ESC ?
// Sweep
// by BARRAGAN a href="http://barraganstudio.com>">http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
void setup()
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop()
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
1290 members
51 members
11 members
182 members
Powered by
