x_angle += dt * (gyro_angle - x_bias);
P_00 += - dt * (P_10 + P_01) + Q_angle * dt;
P_01 += - dt * P_11;
P_10 += - dt * P_11;
P_11 += + Q_gyro * dt;
y = acc_angle - x_angle;
S =P_00 + R_angle;
K_0 = P_00 / S;
K_1 = P_10 / S;
x_angle += K_0 * y;
x_bias += K_1 * y;
P_00 -= K_0 * P_00;
P_01 -= K_0 * P_01;
P_10 -= K_1 * P_00;
P_11 -= K_1 * P_01;
x_angle = kalman filter state estimate
now was that realy so hard?
gyro_angle = gyro input in rad per sec
acc_angle = accel input in rad
dt=time since last loop
Q_angle= 0.01
Q_gyro= 0.03
R_angle = 0.7
x_angle = final estimate
Very nice. Can you define the variables for us?
ok .
the rest of the vari's are filled in by the filter itself. x_angle is in rad
So the Ps and Ks are just temporary variables?
The output is a two-axis X and Y angle?
yes on the Ps and Ks
single axis
Since I am a really big idiot, How can this be modified for x and y axis filtering?
Q_angle and Q_gyro are inverse of standard deviation?
R_angle is convergence factor, the smaller - the faster we converge from gyro towards accelerometer angle?
I see no problems for it to work with degrees... right?
Hi!!, i implement this code in the Mc and i mounted on the airplane.... the x axis of the accelerometer is pointing to the airplane nose so... when the airplane starts to run the angle drifts as the ariplane accelerate... can i solve this problem with kalman filter o what i shoul use....
Pls!!! Help!!!
Thks.
So I believe the title of this post aptly applies to me!! I pirated your code and matlab'ed it and let me say, WOW! So, what's the next step from here? I suppose that it is not as simple as running two independent loops for pitch and roll. Any further advice on how to proceed?
Here's the code in Matlab for anyone interested.. Hope I implemented this correctly.
evalin('base','clc,clear')
dt = .01;
acc_angle = sin(.5*pi*(0:dt:10));
t = (0:dt:10);
for i = 1:length(acc_angle)-1
gyro_angle(i) = (acc_angle(i+1)-acc_angle(i))/dt;
end
acc_angle = acc_angle + rand(1,length(acc_angle))/5;
gyro_angle = gyro_angle + rand(1,length(gyro_angle))/5;
P11 = 0;
P10 = 0;
P01 = 0;
P00 = 0;
Q_angle= 0.01;
Q_gyro= 0.03;
R_angle = .7;
x_angle(2) = 0;
x_bias(2) = 0;
for i = 2:length(acc_angle)-1
P11(i) = P11(i-1) + Q_gyro*dt;
P10(i) = P10(i-1) - dt*P11(i-1);
P01(i) = P01(i-1) - dt*P11(i-1);
P00(i) = P00(i-1) - dt*(P10(i-1)+P01(i-1))+Q_angle*dt;
x_angle(i) = x_angle(i) + dt*(gyro_angle(i-1)-x_bias(i-1));
y(i) = acc_angle(i) - x_angle(i);
S(i) = P00(i) + R_angle;
K0(i) = P00(i)/S(i);
K1(i) = P10(i)/S(i);
x_angle(i+1) = x_angle(i)+K0(i)*y(i);
x_bias(i+1) = x_bias(i)+K1(i)*y(i);
P00(i) = P00(i) - K0(i) * P00(i);
P01(i) = P01(i) - K0(i) * P01(i);
P10(i) = P10(i) - K1(i) * P00(i);
P11(i) = P11(i) - K1(i) * P01(i);
end
plot(t,x_angle,'ro')
hold on
plot(t,acc_angle)
hold off
nice job
I don't see the point of using a Kalman filter if you assume the noise variances to be constant. The Kalman gain coefficients K_0 and K_1 converge to constant values in this case, since they don't depend on any measurement. So instead you can reduce the filter of the (matlab-) example to :
y(i) = acc_angle(i)-x_angle(i);
x_angle(i+1) = x_angle(i)+0.0233*y(i);
x_bias(i+1) = x_bias(i)-0.0209*y(i);
You omit all P-stuff and the CPU intensive divisions by S that way. Moreover the gain doesn't need to converge.
I think Kalman filtering is only useful in this context if the variances are continuously monitored and evolving over time (for example, R_angle could be increased during accelerations, turns or at resonance frequencies of the engine). But this isn't that easy.
I totally agree, once the K and P matrices convege they could be hard coded to streamline the computation. As you mentioned the ideal application would be to model the error (uncertainty) of the system and have the gains dynamically adjust accordingly.
