Hi all !
I need help about my MinimOSD freshly unpacked.
I've triple checked the cabling and I don't know why I've just a black image on my screen.
There is a suspicious comportement when I power on the system. I explain how it happens:
1. Connect correctly the Vin/Vout/RX/BLK between APM, MinimOSD and video transmitter
2. Power on the APM
3. Connect the battery balance connector 12V to the MinimOSD
At point 2, the ST led (orange) blink and the D PWR (red) led power on and still.
When I do the point 3, the ST led shut off and the A PWR led power on and still.
After that, I just have a black screen... It's weird because the system worked at least once!
The firmware is up to date and I use a XBee but I've not connected the TX port on the minimOSD.
What's wrong ? Someone can help me ?
Thanks in advance ;-)
Jerome
Permalink Reply by vilnis.lauva on May 11, 2012 at 12:07am Do you use the same battery for video and APM ?
Sadly I blow out two minimOSD, first one by don't knowing it, second one just accidently. If you use common ground on video and data input (and by using one battery you definitely do that) your minimOSD is dead.
There must be huge red letters in minimOSD wiki not to do this which can looks like normal thing like common ground.
Now I just want to know what exactly blows out, maybe diydrones can give some helpfull hand. I changed max chip, but still no picture, atmega works fine.
Permalink Reply by Jérôme Niklès on May 11, 2012 at 2:01pm Thanks Vilnis !
Yes it's the same battery... It's saddly for these MinimOSD :(((
So the good way is to build the system like that ? https://code.google.com/p/arducam-osd/wiki/Customers_Setup
With a specific battery just for the VideoTX and the stage 2 of the MinimOSD ?
Permalink Reply by vilnis.lauva on May 12, 2012 at 10:51pm Yes, it's the way to go, seperate batteries. In fact, it's better for picture quality too.
But I "migrated" to remzibi OSD loaded with minimOSD software from Hazy.
Permalink Reply by Jérôme Niklès on May 13, 2012 at 12:56am It looks like great !
Can you tell me more about your config ?
Permalink Reply by vilnis.lauva on May 14, 2012 at 12:57am It's this one http://code.google.com/p/hazys-osd/
As I have one remzibi in shelf and just give it a try, and it works the same way as minimOSD. Now only thing is to somehow get current and rssi from APM2 to osd.
This is my first fly with this modified remzibi osd, looks it works ok.
Permalink Reply by Jérôme Niklès on May 14, 2012 at 4:33am Perfect !
I will try this soon !
Thanks for the help !
Permalink Reply by ronang44 on June 3, 2012 at 6:58pm
Permalink Reply by Jérôme Niklès on June 11, 2012 at 3:24am Do you mean that the MINIMOSD cannot be powered from the main battery and need it's own power source? > Yes! You need a dedicated power source for the minimOSD and your FPV system.
Can I run it with a 2S pack? > No ! Because a 2S pack produce 7.4V and you need 12V.
Permalink Reply by Chris Kreuzer on June 12, 2012 at 7:34am Really 12V?
Permalink Reply by Jérôme Niklès on June 12, 2012 at 7:39am Chris, the documentation say that on the first page:
The approach is to use two external power sources: 12V from a Lipo Battery and 5V from APM:
Permalink Reply by Chris Kreuzer on June 12, 2012 at 7:51am up to 12V... or not?!?
Permalink Reply by Jérôme Niklès on June 12, 2012 at 7:57am You need 12V from a 3S batt. It doesn't work with a 2S or a 4S.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1288 members
24 members
78 members
51 members
682 members
Powered by
