Has anyone tested this version of Pixhawk ?
http://radiolink.com.cn/doce/product-detail-116.html
no. post pictures of the PCB inside if/when you get one.
I've seen clones that used proper components, and probably even low tolerances on resistors, as well as garbage , where capacitors, buffers, supercap, polyfuse, power selector IC was gone, or severely reduced.
so you never know until you open ans see components and PCB/soldering quality.
I have looked for information or reviews on internet and the only web page with a little review is the following web:
http://bbs.5imx.com/forum.php?mod=viewthread&tid=1172315&hi...
You will need translate it from chinesse...
I have ordered one set from Radiolink... Pixhawk and M8N GPS...
I hope had enought time to do a complete review of that set as soon as posible...
I will publish my impressions...
Hey There, I have one of these radiolink pixhawks and am having a small problem with it. I can not power it using battery/servo rail. It powers up fine via USB but does not boot when connected to battery. Wondering if it's a bad board or if I am doing something wrong.
hello, I`m newbie on this forum and my current configuration base on naza solution.
I want to replace my naza by any open hardware based solution and now I looking for the best quality 2 price replacement. there is not so many posts and comments related this radiolink board and if you can please share your opinion about it. Are connectors same as in 3DR or different , how about overall quality ?
Hi all...
Recently, five days ago, I have received the "Radiolink Pix" set that I ordered in July... a little bit late to do a quick review because it is the second set that Radiolink sent me... the first set never arrived and I think it was lost by the post service. Now I am out of my vacation time and I have little time to do it. I hope to have enought time to do it as soon as posible.
Thanks.
Finally I could test Radiolink pilot in Tuffwing frame (excelent frame by the way), about the pilot I found 2 errors:
1. SPKT/DSM port is not the standard for Spektrum receiver, so you need to cut the plug to install it
2. I order 2 GPS antennas, 1 of them was damage
Different conectors as in 3DR and SPKT/DSM didn't fix.
One more  question from my side. I did review hi-level description only and there is a note that board supports 2MB flash.
Do you know is this true or it`s suport only 1M|B as well as 3DR?
Yes, it support 2 M flash
