I have just upgraded my Iris Tarot Gimbal to v1.5 while changing the motor power settings to get rid of Jello.
Now my Gimbal just levels itself and then looks downward and will not respond to the controller tilt anymore. I'm assuming this is something to do with the update. I have tried it wired like in this video http://youtu.be/aHkfuRddrOY look at 1:30
which is the way it was, and also the other way http://copter.ardupilot.com/wiki/common-tarot-gimbal/
But i have no tilt control. is this something to do with controller type in the software?
the Gimbal will stay orientated when I move the iris round.
Any help much appreciated
I screwed up the wiring once after upgrading and thought the same thing. The wires going to the pixhawk look weird in the instructions. Try using the components in the photo as a reference. My Gimbal points straight down without the wires attached. (or before I turn on my radio)
The standard settings can be found here. They are also referenced here: http://copter.ardupilot.com/wiki/common-tarot-gimbal/
Thank you for the link, don't know how I missed that page.
Try "write settings to flash" after ensuring it is set to MODE2.
I had that same exact issue.
thanks, that did the trick. I couldn't get the software to change it to Mode 2 so i had to load the standard config file. all good now, did 50 minutes flying today and worked perfectly
Sorry if you've done this already, but did you upgrade both the controller firmware and the motor firmware? You'll also need to recalibrate the camera position (level, facing straight down) and reset the min/max tilt. I messed with this update for a while and got it working, the jello is indeed gone.
I emailed 3DR when I went through this to see if they could let me know what the factory parameters on the gimbal should be since they're reset after the update, but no luck. Like the TX settings, gotta just noodle it through I guess. If I recall, there's also a tricky setting in the firmware in regards to how it handles TX input...anyway, it's all here (except for the calibration)..
http://youtu.be/A2WXguD2Ghs
Make sure the R/C transmitter is on. With the R/C transmitter off, the Gimbal will point down.
Also make sure that the cable from the Pixhawk to the Gimbal is correctly connected.
when I plug the wires on the bottom of the iris in, it always points straight down. if I power it without these wires plugged in it points horizontal. Now I'm very suspicious of the upgrade stuffing something up.
In the gimbal software, what receiver type should it say?
which wiring diagram is correct? or doesn't it mater
