I am having a problem with my APM v1.0. I had the unit up and running as advertised with no issues, however, I did suffer a small crash with no obvious physical damage to the APM or the IMU. Since then, I have had no output to the esc from APM. The speed controller has been tested and works the reciever works and all other channels work on the APM. When I connect a servo to the throttle channel on the APM the servo works. When I connect the ESC to another channel, the motor works on that channel. I have run the radio tests and PWM tests and there are no obvious errors. I have also reloaded the APM code as well as re doing the setup and re loading the PPM encoder. At this point I am stuck. I would appreciate any input from the group.
Thanks,
Mike
Tags:
thanks for the input, I alredy thought of that and checked the traces and the solder joints and everything seems to be in order. If the output was shorted or damaged then a servo shouldn't work on that line (and it does). And v1.0 refers to the hardware.
also forgot to mention that I have tried multiple ESC's hooked up to APM and the same problem exists.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.51 members
1299 members
24 members
48 members
111 members
Powered by
