Hi there. I purchased the ArduCopter Quad v1.1 KIT, Full Electronics from jDrones. Have worked my way slowly through the setup - this being my first attempt at wielding a soldering iron and the such.
Have reached the point where I need to look at batteries. Naturally, I have a couple of questions...
The kit comes with a D8R-Plus receiver which has an operating voltage range of 3.5V-10.0V. Does this mean I am restricted to using a battery with a voltage <10V? Or does the ESC handle those issues?
Secondly, I am trying to calculate the maximum takeoff weight. The kit came with 4 x D2836(-9?) brushless motors. According to the spec sheet they have a "Max Pull" of 850g. So, does that mean max t/o weight is 4 x 850g = 3400g? Here is a pic of the spec sheet...
Thirdly, the receiver pin configuration "appears" to be the reverse of the configuration used in the example setup instructions at http://code.google.com/p/arducopter/wiki/AC2_Radio . Here is the pic of my pin configuration. Do I have it correctly configured?
Many thanks for your help and patience.
Tags: configuration, lipo, weight
Permalink Reply by al on June 3, 2012 at 8:10am well i ain't no expert...
the RC is powered from the APM if I recall right, that is 5V (you can see the connection you made - ok - in the pictures)
yes maximum force is 3400 g, but that doesn't mean you will be able to fly with that weight, because you will need full throttle to bring it there, so you can't do anything after lift off (if you even get there). I believe a gross approzimation of the mass of the arducopter is 1.5kg, so a 400 g extra load should be ok (it flies less time though)
connections look good, their image is just an example, you do it however your receiver is designed. Just make sure each signal goes where it is supposed to (cannot check that from a picture).
You seem on the right way.
Just test before flying.
Permalink Reply by Simon on June 3, 2012 at 8:56am cheers al. I appreciate the clarification on the weight issues.
All seems to be on the right track. Have just completed the ESC calibration and all ok. So pin configurations on the receiver are ok.
Moving on. Thanks again.
Permalink Reply by al on June 3, 2012 at 9:22am i have done the assembly not so long ago, and I had a lot of crashes.
Now the small Atmega is burned.
So just make sure you have everything by the book, but also straight in your head (i had everything by th ebook as well... as least i thought so).
And come back with any questions.
good luck
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
12 members
249 members
183 members
693 members
Powered by
