After having some problems with previous version of Arducopter code (including ardupirates) i tried current, second version. I must say that im impressed, it flies quite well at default settings ! Quite, because i must solve 2 things, im flying only in stabilise mode as for now.
1. Quad is prestty stable, but also a bit "nervous". From time to time its catching short oscillation, also its oscillating a bit at quick descent. What parameter should i change (rise or lower ?) to correct it ? Wiki suggest to focus at Kd, but maybe in this case its matter of "P" ?
2. This matter is a bit more complicated. During flight with first version of Arducopter (and ardupirates) i noticed that after crazy and fast flight quad its drifting quite strongly to opposite direction for some time. For example if i did some fast forward flight with some turns and so on, and if i try hover just after that - quad drifts backward quite strongly. After some time, about 10-15 seconds quad get back his level and hovering more or less in place again. Also landing and reconnecting battery do work.
Unfortunatelly i see that same behavior with ACM2, but not so strong like in previous version. After fast flight forward and relasing sticks, quad for about 5 seconds tries to drift backward till it get back his level and hover normally. What can be reason of such behavior ? In my opinion, in ACM2 it looks like quad is trying to stop his forward move when i relase sticks, but this "contraction" is too strong making him not only stop, but also drift backward. What parameters i should try change (rise or lower) to correct this ?
My setup:
- APM 1280 + Oilpan (version before 1.4.), no magneto, no sonar, no GPS
- 850 kV RCTimer motors with 10x4.7 APC props
- own frame with 50 cm motor to motor distance
- 1 kg RTF weight
Greg
Really nobody ?
I am also experiencing the short oscillation which you have. I tried changing the D value to -0.1 and +0.1 but both were un flyable. I then lowered the P value to 0.5 and then to 0.4 and it is slightly better but still not right. I also lowered the stabalise damp value but still have oscillation.
try increasing the stabilize damp value. That helped me.
if you put too much Ki the AC will back when you release sticks.
Put less i parameter.
As Kp i think that you can change "STABILIZE DAMP"
2.   I have exactly the same problem that you describe! Sometimes I have to give full stick movement to stop the quad from flying away.. Did you solve this problem?
Hello Kristian,
Soon after this post i been forced to crash my quadrocopter. He again had HUGE problems with leveling, once been escaping right so strongly that i been not able to stop him even will full action at my transmitter sticks. I had no other choice than make very hard, half-controled landing because i been affraid he will hit cars parked near of our airfield. Damages were not too big, but such situation should never happen. I wanted fly Arducopter with FPV in next couple weeks, buy how i can do this if such things happen ? If he will get crazy again 1 kilometer away somebody can get hurt because problems to control it !
So yes, i solved this problem, i forgot about Arducopter, at least for some time, and bought MK flight controller. I had no other choice, after this what i seen i cannot trust arducopter at all as stable FPV platform. No matter how much i like this open source idea and Arduino projects generally, my unit (maybe its faulty, i dont have idea) at current code, behaves sometimes extremally unpredictable, what can make it potentialy dangerous. I cannot handle such risk in FPV flying for fun and relax. Maybe will come back to Arducopter when things will get more stable and sure than are now.
Greg
I agree. The problems have to be sorted out before I can use it to anything serious. I decided to give it a try again, and have started a new thread about this problem. Will try changing some settings, logging etc. If I don't get any results this time I will probably also have to go for another controller.
