hi,
i have this 4 pin sensor ar home
, and i was wondering if it can be used in complement or instead the classic sensor.
Anybody succeed using these object avoidance?
anybody tried?
 thx for your time
I would also like toknow have the same sonar
lemme know pls if you have any tip
Hello
I don't think so. Arducopter reads the analog value of the ultrasonic sensor. This one does not have an analog output and the distance is measured by sending a pulse to the pin trig and counting the time it takes to receive the echo on the pin with the same name. This method was implemented on Megapirates NG.
I'm working on a solution for this. The current MaxsonarXL implementation uses a generic analog source reader with a default median filter. The interface returns centimeters, so a simple wrapper around i.e. the New-Ping library might work, but I'm worried about the delay of measurement and how it might effect the control loop. To get around this I'm building a simple integrator circuit to convert the pulse width from the HC-SR04 into a voltage. This requires an extra pin to clear the voltage between readings, but if it works then it will just be another implementation of the AP_RangeFinder interface.
My first design gives a signal between ~.3V and 3.3V out to about four meters https://www.circuitlab.com/circuit/4etd6v/integrator-for-hc-sr04-ul...
though that design is based on components I had on hand, it really should have a (forward bias) diode between the source and the pull down transistor, and the signal would be much cleaner with a FET. And the transistor's base should be the "clear" pin. And adding a timer and a buffer would make the functionality very similar to the maxsonar devices.
... it's a work in progress ^_^;;
IIRC, the analog output of the maxsonar devices are not the most accurate one. Would make more sense to do the other way around and change the arducopter to read the digital output of the sensors. This way, both could be supported easily. MegapiratesNG already does that.
though it may be less accurate, it is the fastest output to read. It also requires fewer pins. And in this particular case the HC-SR04 doesn't have a digital output, it's just analog in the time domain.
also, this deserves a cross reference here I think:
http://www.multiwii.com/forum/viewtopic.php?f=7&t=1033&star...
So just to see if i guet this right.... i have buy two of this (one as spar parts) to use in my quad with APM2... will it work???!
short answer: no.
long answer: check back in about a month and I may have a solution for you. or someone may have done it already and I simply haven't been able to find it.
I currently have a testing problem as I broke one of the motor mounts on my quad and jdrones is refusing to ship me a replacement, and I also haven't finished the software. so right now it's vapor, don't depend on it.
Ok i will get back to you, thanks.
I am also interested in this.  I have both types of sonar, but I am trying to encourage my local community to build rovers and I am trying to get the price point down as far as possible.  As I can get the HC-SR04 down to $1.50 in volume, I would like to be able to use this.
I am working with these on another project, so soon I may be able to help.
