Voltage Drop on APM Power module
I have introduced some voltage/current issue into my quad but I cant track it down.
Here is the Breakdown of what I have:
1) 30a 4 in 1 ESC SKY III (Timing High)
2) MT4006 Motors
3) (2) 3s 5100 3dr Batteries
4) 14x5.5 CT props
5) 14 gauge wire
6) APM Power module
7) Auqacopters bullfrog frame
The weight all in is 2200 grams.
Here are my calculation from eCalc
http://ecalc.ch/xcoptercalc.php?ecalc&lang=en&cooling=excel...|mt4006-13&gear=1&propeller=t-motor_cf&diameter=14&pitch=5.5&blades=2&project=Bullfrog
The Quad will hover at 50% throttle but the voltage drops very rapidly. It drops to 10.3 in under 10 minutes triggering failsafe. I hooked a monitor up to the battery and spun the motors up to 50% (loaded ). Under load the power module shows 10.3 volts while the battery monitor still shows 11.5. I have swapped out the battery packs twice
I have tried to calibrate the power module via the instructions on the wiki. The voltage matches when with no load hovewever under load the power module voltage Drops off quickly.
a couple of other observations.
1) The current draw from the power module is higher that I would expect 27amp vs 20amps
2) The ESC is really heating up 160+ F, while the motors are at room temperature.
3) eCalc says I should 20 min of flight time. but the power module goes to failsafe after about 10 min.
4) Pluging my batter in right after the flight to the monitor reads 11.9.
I have read other similar threads about unexplained voltage loss but they do not seem to draw any conclusions. (http://ardupilot.com/forum/viewtopic.php?f=49&t=7265)
Should I take it for granted that the power module is bad. aka showing the incorrect voltage, or is there something else going on.
What does a normal voltage drop look like?
Thanks for any help or suggestions.
Hi Eric,
I know it's been awhile since this post, but I've just started experiencing the same issue with my Hexacopter. I think I've been having the problem all along, but I've just added a FrSky Voltage Sensor that give me real-time readings while in the air. I've calibrated the Pixhawk power meter but it would always read about 1-1.5V below what the FrSky sensor was reporting at the balance cable, so I just started going by Lowest Cell Voltage from the FrSky sensor...BIG MISTAKE!
I was flying the other day and my Lowest Cell Voltage reported to my Taranis read 3.6V, so I assumed the voltage at the flight controller was about 10.8V (3.6V x 3s) which should have a little bit of flight time left, or at least enough to safely bring it back for a landing. Unfortunately, I looked up to see my copter slowly dropping out of the sky and crashing (fortunately a slow descent from only about 15 feet and almost no damage). My only conclusion is that the power module and/or power distribution board really are eating up more than 1V between the battery and the ESCs/Motors. Very frustrating!
I've ordered a power module/BEC kit from Christian at http://www.mauch-electronic.com/ which I'm hoping will address some of the resistance and calibration accuracy issues.
Same problem, tried many power modules.. still experiencing this problem. Hope someone could help. I have Micro APM from HobbyKing and Pixhawk both using different power modules, both of them have same problem described here. Can't figure out WHY!!!!...
Hi Eric.  If your ESCs are getting hot then the first thing I would do is lower the timing to Med. Low or even Low (higher timing rates normally work better with high kv motors.)
Regarding voltage loss and flight times, are you starting with fully charged batteries - i.e. is each cell is at a full 4.2V?
In mission planner, is the displayed voltage exactly the same as when you measure the battery (connected) with a reliable voltage meter?
What voltage is your failsafe set to?  If your 3S flight battery measures 11.9V on landing (after a triggering an alarm/failsafe) then it's set to trigger way too early.
Current draw should be 21 A  with a good motor so with 10200 mAh 3S you should fly 28 minutes .
With 27A and 10200 mAh 3S you should fly 22 minutes.
So apparently your batteries are almost dead .
John R said:
Hi Eric,
have you tried the new power module? Is it working?
Power modules are still first generation.  They are not only inaccurate but are also inaccurate at different values throughout the spread of your battery voltage.  This means that even if you calibrate it at full power it will be inaccurate as soon as you throttle up at all.  This limitation is not severe and for most it is ok.
Drain the battery to a voltage above your desired failsafe and calibrate it there.  The idea is that when it approaches that known voltage the accuracy will be at it greatest.  There are power modules that are not only voltage accurate but current accurate, the trade off is that they require a BEC and cost $21 currently.  (BEC is an additional 20)
You are running a 3S system.  Your flight time is about correct.  Make sure they are charged up fully to 4.2V for a regular LiPo or 4.35 for the High Voltage LiPo's.  Higher voltage systems have longer flight times.
Do not depend on E-Calc ever again as it is not accurate enough.  Get your results just as you have, by building and testing the systems.  Remember your results.
Resting voltage will always be higher than what the battery does under load, it is a chemistry issue and is normal behavior.
Your ESC heating up could be a number things, inlcuding: cheap ESC and/or components, inadequate airflow for cooling, the rating of the ESC is not as stated, bad solder connections, a failing ESC or a mismatch between the voltage rating of the ESC and the 3S battery.  In my experience, the lower the voltage the hotter they run but not always.
A normal voltage drop will be nearly a linear downward line followed by a cliff at the very end, typically when a cell is around 3.3V.
Good luck bud!
Link to power modules that are voltage accurate and current accurate? thanks! :D
BEC ... is only a DC-DC step down (and maybe a filter)?
Yes I'm currently running the Mauch Power sensor and BEC on my Hexacopter and it works great!
I'll be honest, the voltage drop is still there as soon as the load it applied (16.8V fully charged, drops to about 15.6-15.7 as soon as I throttle up) but then the voltage drop after that is extremely linear and I can use my batteries to their full capacity without hitting a low voltage alarm or low cell voltage, although I always land with about 25-35% capacity remaining.
The other advantage is the voltage and current reading from the sensor are extremely accurate at all voltages/currents. It measures correctly starting as low as 0.5A which the regular power modules cannot do. I've tested the % remaining reported by my telemetry and compared that to what my charger says I put back into the pack and it's pretty much dead-on. I would highly recommend it.
There are now two components instead of one to install. You'll need the BEC to power the sensor as well as the sensor itself.
Also, I would recommend making sure you get the right sensor for you application. Now that I have an accurate measurement tool, I know that my Hexa draws 22-23Amps at hover, and a max of about 70-80Amps at a full punch-out (which I rarely do since this is an AP rig). However I ordered the 200A sensor which works perfectly, but comes with larger gauge wires that I had to route within my 550 frame and solder to an XT60 connector. The 100A sensor would have worked just fine and would have been easier to manage.
thank you john
I not had a good experience with the Mauch Ubec and current sensor.
The current reading that appears on Mission Planner is not stable , it varies a lot , much more than the standard 3DR current sensor making the current data unuseful .
Mauch told me it was normal because it is a HAL sensor but I have another supply board with current sensor that is much more stable than the one from Mauch and it is a HAL current sensor.
About the Mauch ubec , the basic version is a low cost D-Sun switching converter with a resistor instead of a trimmer .
I had several headaches with my compass and also very strange behavior with a clone Pixhawk after I mounted  Mauch currrent sensor and Ubec .
Mauch gave a great support but finally the problems remains .
I do not want to damage his reputation , I'm just telling  my experience with his products , I might been unlucky or I  just did something wrong.
I solved my problems installing Airbotpower, an high quality supply board with current sensor , it cost a lot more (about 80 Euro ) but I will not mount anything else on my next copters.
Airbotpower board
That Airbotpower board looks pretty cool and a nice all-in-one package. Very impressive design. I wonder if there are any US suppliers that carry it.
I have not had the same problems with the Mauch sensor and my current readings are extremely stable and accurate. I normally use telemetry via the Android Tower App as well as FrSky Telemetry on my Taranis so I can't comment on real-time display in Mission Planner.
Come to think of it I do have pretty regular "inconsistent compass" errors when powering up but that goes away if I rotate the craft around. I'm not sure if that started only after I installed the Mauch sensor or if that started earlier. On my S550 Hexacopter I moved the Pixhawk in between the top and bottom plate sandwiched with some Zeal gel so it's sitting only 1-2MM above the integrated power distribution board. My primary compass on the mast works perfectly though.
20 minutes flight time with 2200g gross weight sounds quite much. Has the eCalc calculated the total weight correctly?
You could perhaps reduce the fail safe limit to 9.6V for 3s lipo as 3,2V per cell is still safe for the battery. You could also check the initial condition of the battery, is it still good to go?
I think it is quite normal that battery voltage is a bit lower under heavy current load. Usually a very bad condition battery looses voltage very quickly under load.
Oh yes and of course you should calibrate the power module reading by measuring the actual battery voltage from the battery terminals at the same time when it is connected to the Pixhawk and other system for example using multimeter. (Measure voltage from battery terminals and adjust the voltage value accordingly with mission planner).
