Hi Forum, I am a fairly new user to APM2 (made about 4 successful flights on a skywalker.) And I am looking at building a twin boom aircraft for taking Aerial Pics to be used for GIS, land surveying etc.. I initially built an off the shelf twin boom called the URSUS, but due to its wooden spa construction, it broke in half in mid air. I have added glue, carbon and ply reinforcements, but now its too heavy to fly. Therefore I thought i'd try and build something myself using its power system
Here are my objectives
Based on some research, I have discovered that aircraft in the 2.2 - 2.6m range can achieve this. I have a moderate amount of building experience, using polystyrene, depron. But have never tried to build anything that performs well.
I am going to make the Fuse out of fiberglass, and the wings out of EPP.
Some technical details...
Wings
Fuselage
Power System
Some pics... there will be a nice cowl on front and back of fuselage, but i cant do that with my limited CAD skills!
This thread and idea is a product of realizing that the lower end off-the-shelf airframes are not capable of what I want to achieve. I have reached that conclusion in my Arial Photography thread here.. The Skywalker is great, but can't fit a roll gimbal in it (I keep getting pictures at different angles). The Ursus is nice, but the construction is too weak for my needs. Whilst working on a new airframe, I will be continuing to use the overweight ursus to perfect my roll gimbal. However a new airframe is needed to get longer flight times. I quite like the medium priced hugin, but thats a little out of my price range right now.
I can get EPP wing cores cut for £40, and a fiberglass fuse made for next to nothing.
I have a few questions -
If anyone with aerodynamic knowledge has any fairly simple calculations to see if this will work, please could you let me know! or any other thoughts for that matter, positive or negative!
Cheers
Tags:
Permalink Reply by Richard Unwin on June 14, 2012 at 7:46pm Welcome to the challenge that making your own plane is...
I will add my ideas for your answers below.
1. max out this space which will allow for changes to prop sizes if needed, but its a trade off between keeping the booms rigid and also how high the undercarriage is to allow the max prop size to be run. Also depending on where the undercarriage is can change what happens on take-off as the front wheel leaves the ground and the planes attitude changes the prop can strike the ground.
2. My original wing design was 2500mm long and 300mm wide (and was going to be a Clark Y but the foam cutter changed it to a different shape with a curved bottom) It flies well and just mushes out when trying to stall and doesn't drop a wing which is great. I will ask the cutter what the shape is.
3. I used 12mm Carbon rods with a 1.2mm wall section and mating 14mm carbon rods that allowed me to make sockets to plug the tail section on and off.
4, I used a general rule of thumb of %15 of main wing area for Elevator surface and %7 for the rudders, as for the boom length I could only buy the rods in 750mm sections but with the tail joined on its almost 900mm long, my main idea was to get the tail back as far as possible while still be rigid, the further back it goes the more stable the plane will be and the less pitch sensitive the elevator control will be, give a nice stable flight platform.
5. I built a H tail as I believe that the APM units still dont like controlling a V tail, ( if I am wrong on this someone let me know)
I have posted a few pictures on my blog let me know if you have any other questions.
richie
Permalink Reply by Richard on June 15, 2012 at 1:16am Hi Richie, your answers have been extremely helpful, and enough for me to go on, Your blog is an excellent reference. A friend of mine has already started on the fuselage, As we knew the approximate size for this. I am going to try and build to the rough weights you have spec'd out in your blog if that okay, as they are quite similar to mine. My fuse is a bit taller than yours.
A friend has already starting vacuuming the fuse mold - some pics...
One more question if possible,
I was thinking of using two thick Carbon fibre tubes in the front and back of the wing to strength. And noticed you have thin spa's top and bottom, Is there any reason you went for that strengthening method?
Your build looks really good by the way!
Rich
Permalink Reply by Richard Unwin on June 16, 2012 at 6:13am
Permalink Reply by Richard on June 16, 2012 at 2:47pm Richard, Cheers for the advice, I think I have enough info to continue with the build. I guess it is just going to be trial and error whether I get it right first hit. I guess it's lighter to use thin spas to reinforce the majority of the wing as opposed to running 2 hollow booms the entire wing length.
I will keep this thread updated with progress...
Cheers for the help, Its very useful!
Richard, Several of your questions might be addressed by an old publication - Model Glider Design by Frank Zaic
I recently finished it and in it he discussed (pre 1938) tail boom materials/sizes, wing aspect ratios, rudder sizes, elevator sizes, and even tail planforms.
Most of your questions, except the fact that we now have carbon fiber materials, are discussed from the perspective of gliders.
As you are starting with a somewhat clean sheet of paper, perhaps patterning your new bird after some other twin boom designs might be useful? Listed below are some online plans to inspect and perhaps get an 'average' value from.
Netopyr Pushaire SIPA Mini jet XP-3
I would also average in dimesions from the OV-10 Bronco, P-38 Lightning, Cessna Skymaster, and maybe others listed HERE.
Perhaps some dihedral is also appropriate because you need some built-in stability for photography?
I see a white paper on this subject... oh to have more time in a day. This website stimulates so many ideas.
Permalink Reply by Richard on June 16, 2012 at 2:49pm Hi R.D. Starwalt, thanks for the info, the plans youve listed are useful to me and I have observed surface area ratios, and feel i have enough info to continue the build. I am going to make the entire frame modular, so if the booms are initially to long/short, i can change it easily.
Cheers
Permalink Reply by Richard on June 18, 2012 at 3:01pm Update, I have been doing some research, and taking in all your advice, and have refined my measurements and sizing's accordingly. The below is an accurate scale drawing of the measurements. Here are the important details...
Fuselage
120mm x 120mm square box section 600mm long, with cowls on each end.
Tail booms will be 12mm outer dia with 1mm wall thickness
Wing
Chord - 300mm
Wingspan - 2400mm
Aspect Ratio - 1:8
Profile - Clark-Y
Wing area Calculation = 2400mm (span) x 300mm (chord) = 720000mm sq. Subtract Fuselage area = 36000
Total wing area = 684000mm sq.
Elevator
Elevator needs to be 15% of wing area so 15% of 684000mm sq (total wing area) = 102600mm sq (elev surface area)
The elevator does look a bit large, but I guess this thing needs to be stable.
Vertical Fins
I am going to make this aircraft a T tail as i have heard APM doesnt like inverted V tails just yet, but the tail will be removable anyway so when it is more supported, I can just change it over.
Power System
Eflite power 60 with 14 x 8 Prop. It says it is good for models upto 4kg weight. A bit expensive though. And ideally i would like to run this on 3s, but it seems 4s is the minimum. Best get saving for some new packs! If anyone has any recommendations for motors that would be great.
And now onto the visual.....! My trial of AutoCAD 3d studio max has expired, so 2d visuals from now on!
As always - if anyone has any positive or constructive feedback, please let me know!
Permalink Reply by Veikko Vierola on March 21, 2013 at 3:16pm Hi, it looks good. I planned pretty similar design once with two engines. http://diydrones.com/xn/detail/705844:BlogPost:897647. Let me know how it flies when your plane is ready.
Permalink Reply by Wanabigaplane on June 18, 2012 at 4:07pm Hi, we have some experience with Hugins and our Mugin.
For booms look at ex carbon fibre golf sticks. (In Aus they are a common item at the dump recycler.)
For V tail we used a Vtail mixer we use the normal rudder / elevator APM arrangements. The rudder output goes to to the nosewheel, then the rudder and elevator go to a V-tail mixer. Neither the pilot or the APM notices the difference.
With T tail or H tail you have a problem with rigidity. I think you are much better off with the horizontal stabiliser between the booms. With two rudders you will either need an extra servo, or a boom between the rudders.
With a V tail, the join of the two elevon halves is a weak point that needs consideration in the design phase. You may even consider a strut between the booms to make the tail end a strong triangle.
With the long flat sides of the fuselage out front, you need good tail volume. However, the weight in the nose to counterbalance this becomes a problem which wth electric is solved with placement of the batteries.
Think how you are going to transport and assemble this bird at the field during the design phase. Having put up with our arrangement, I long for the alternative where the tail, booms, and mid wing all stay in one piece for transport and assembly.
Plan your nosewheel undercarriage carefully. It is going to be long, and with the need to steer it, becomes a bit difficult and vulnerable to a bad landing. You need either crash resistance or easy in field replacement.
Jack.
Permalink Reply by Richard on June 19, 2012 at 6:21am Hi Jack,
Cheers for the Info on the Golf sticks, I have found 1000mm x 12mm outer dia (1mm wall) Carbon fiber tubes for £11 each. Which should work, not quite sure if 1mm is going to be strong enough, as i cant seem to find carbon fiber golf clubs anywhere.
I hadn't thought of using a v tail mixer, wouldthis one be okay? I would definitely like to do a V tail if possible as opposed to H or T tail. If building an inverted V tail, I would probably join the 2 elevon halves with 30 minutes epoxy, I am thinking of building up the tail with balsa, then covering with Fiberglass, that should give it plenty of rigidity.
I am planning on making the outer wing panels removable, and also the booms removable, and also the tail removable. For clarification, is your bird built in one complete piece?
If the fuse, center wing section, booms and tail will fit in the car, I will make them removable/modular, but keep them assembled for quick setup times.
I have already purchased this rear landing gear, it is the CCU14 from this website in the UK, about 1/3 down the page. 190mm high. I have looked around for decent nose wheels, but think i may need to get something machined. Something similar to the one on the Mugin maybe. I have had quite bad luck with the undercarriage on my URSUS 2200mm twin boom airframe, I initially used aluminium rear gear, but then upgraded to sprung steel, but was too heavy, the front strut was quite nice, but kept bending. Here is a picture from that build thread...
I am not sure about making the nose wheel steerable, at 190mm high excl wheel, its going to be a challenge!
Any advice on nose wheel and inverted V tail construction greatly appreciated!
Rich
Permalink Reply by Wanabigaplane on June 19, 2012 at 7:21am I guess any v-tail mixer would do. I don't know anything about that one. Don't forget to test it on fresh batteries as well as low batteries.
I am suggesting the midwing/booms/tailpiece stays together as one structure. The midwing is attached to the fuselage at the field just like a normal model aircraft - for example, two dowels in the leading edge and two nylon bolts at the trailing edge. Minimum assembly at the field, no feeding of cables through the structure, or attachment or clevices. It's just an idea I have - let anyone, who has tried it, chime in and tell us if its not a good idea.
Jack.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1355 members
203 members
24 members
207 members
58 members
Powered by
