Hi Forum, I am a fairly new user to APM2 (made about 4 successful flights on a skywalker.) And I am looking at building a twin boom aircraft for taking Aerial Pics to be used for GIS, land surveying etc.. I initially built an off the shelf twin boom called the URSUS, but due to its wooden spa construction, it broke in half in mid air. I have added glue, carbon and ply reinforcements, but now its too heavy to fly. Therefore I thought i'd try and build something myself using its power system
Here are my objectives
Based on some research, I have discovered that aircraft in the 2.2 - 2.6m range can achieve this. I have a moderate amount of building experience, using polystyrene, depron. But have never tried to build anything that performs well.
I am going to make the Fuse out of fiberglass, and the wings out of EPP.
Some technical details...
Wings
Fuselage
Power System
Some pics... there will be a nice cowl on front and back of fuselage, but i cant do that with my limited CAD skills!
This thread and idea is a product of realizing that the lower end off-the-shelf airframes are not capable of what I want to achieve. I have reached that conclusion in my Arial Photography thread here.. The Skywalker is great, but can't fit a roll gimbal in it (I keep getting pictures at different angles). The Ursus is nice, but the construction is too weak for my needs. Whilst working on a new airframe, I will be continuing to use the overweight ursus to perfect my roll gimbal. However a new airframe is needed to get longer flight times. I quite like the medium priced hugin, but thats a little out of my price range right now.
I can get EPP wing cores cut for £40, and a fiberglass fuse made for next to nothing.
I have a few questions -
If anyone with aerodynamic knowledge has any fairly simple calculations to see if this will work, please could you let me know! or any other thoughts for that matter, positive or negative!
Cheers
Tags:
Permalink Reply by Richard on June 19, 2012 at 6:22am Now that is a strong airframe! and an entertaining video!
Permalink Reply by james sowell on June 19, 2012 at 6:38am can you buy that plane in the video?
Permalink Reply by Wanabigaplane on June 19, 2012 at 7:22am I wouldn't buy any aircraft that has been treated like that !
Permalink Reply by Jake Stew on June 19, 2012 at 8:44am I should have posted links...
http://diydrones.com/profiles/blogs/taigacam-robust-plane-for
Unfortunately the website is in a foreign language...
Permalink Reply by james sowell on June 19, 2012 at 9:59am thanks for the link
Hello...did you consider to buy one instead of making it...bormatec have what you need at afordable price i think...check Maja model http://bormatec.com/index.php?option=com_content&view=article&a...
Permalink Reply by Richard on June 20, 2012 at 3:58am I did, However with landing gear and 220cm wings, and shipping, the total cost is 302 euros / £243. Which is very reasonable for what you receive. And i did consider it. However I am making the entire airframe for ~£100.
Yes It is more work, but I have the time, I do like the Maja though, its a nice airframe.
Permalink Reply by Richard Unwin on June 21, 2012 at 4:18am
Permalink Reply by Richard on July 2, 2012 at 6:31am Hi, Quick question, I have almost all of the parts to continue with the build except the tail booms. I am looking at getting the 12mm outerdiamer, 10mm internal diameter tubes made from pultruded carbon fibre.
I read on the website that these types of tubes are vunerable ot crushing:-
"Pultruded tubes feature 100% longitudinal fibre orientation which gives them excellent strength along their length but does make them vulnerable to crushing forces."
This doesn't sound great, before i click the buy button, does anyone with Carbon fibre knowledge know if they will be strong enough?
Cheers
Permalink Reply by Richard on July 2, 2012 at 12:23pm Update - got two aluminium tubes from the local hardware store - they seem quite light @ 96g each, 12mm Outer dia, 10mm inner dia, 1000mm long. Only £5 each so not too pricey, they seem pretty strong, Maybe stronger than the pultruded carbon fiber tubes, which apparently crush quite easily.
Also looked through some old plane parts i had lying around, and I happen to have an old wing 300mm x 2400mm Clark y wing that I cut myself, it used to have twin engines but they have since been removed, the surface is pretty damaged, but as i'm still waiting for my EPP wing, I think i am going to spend some time cleaning this one up. I am also going to make an EPP fuselage from 20mm EPP Sheeting... The Carbon Fiber fuse a friend made fo rme is going to be too small, I think it needs to double in Length!
below: Carbon fuse 120mm x 120mm x 600mm - Alloy tubes, 2.4m wing
Permalink Reply by Ellison Chan on July 2, 2012 at 12:58pm
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.6 members
24 members
249 members
43 members
8 members
Powered by
