The purpose of this blog is to build a reliable, high performing Bixler drone on a budget.
I have seen some really horrific pictures on the internet of Bixlers with everything taped to the outside. After digging through the internet, I found the answers I needed to build my plane, but the learning curve was pretty steep. Hopefully I can help somebody out and save them a lot of frustration by logging my whole build.
The equipment list:
Bixler 1.1 ARF: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
Motor: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
ESC: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
SBEC (Optional): http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
ESC Programmer: http://www.hobbyking.com/hobbyking/store/__45206__HobbyKing_Program...
APM 2.6 with separate GPS/compass
Radio: DX8
Receiver: AR6210, no satellite
Prop: APC 6 x 4. The HK 6 x 4 prop came with horrible adapter collars and I do not recommend them!
30cm 4 position cable: https://store.3drobotics.com/products/df13-4-position-connector-10-...
30cm 6 position cable: https://store.3drobotics.com/products/df13-6-position-connector-30-cm
5 pin housing: https://store.3drobotics.com/products/df13-5-position-housing
Female-female jumpers (15cm x 7 qty) https://store.3drobotics.com/products/servo-extension-cable-female-...
About using an external SBEC: I chose to do this because I am an RC heli guy, and I am used to using servos that draw ridiculous current. My thoughts are that if you supply the servos separate from the motor, there is less chance of either one shutting down due to over-current draw (but you also add a second electronic device that can fail). I am thinking of when the motor is at max throttle and the servos are fully deflected, such as on a very windy day, the separate BEC will give you some headroom. If space becomes an issue, you can always get rid of the external BEC and use the internal BEC from the ESC.
Programming the ESC:
1. Set up the programmer card as such:
I purposely set the low voltage cutoff to its lowest setting to allow the APM failsafe feature do its job. It is veeeeeery nice, but more on that later. Don't worry about FWD vs REV; you can just switch two of the motor wires if the motor spins backwards.
2. Connect the ESC to the card and the motor (no prop).
3. Plug the ESC into a battery and you should get one tone from the motor, letting you know that programming is complete.
4. Disconnect the programming card and then the battery.
Wiring the ESC and BEC:
I chose to use EC3 connectors in my build, because all of my batteries have them. XT-60 are just fine.
1. Cut the servo power lead off of the BEC at the connector. Solder the BEC power cables with the ESC power cables into your connector. This can be a little tricky, but if you get the solder hot in the connector, you should be able to slip the BEC power cables into the connector after you solder the ESC cables. Just keep the heat on it and slip them in. It helps to have a set of "helping hands", but I use my children instead :)
2. I chose to run my servos at 5V  from the BEC.  There is a jumper on the end of it that lets you select 5 or 6 V. Before I reinstall the electronics I will secure the jumper on the BEC with a glob of hot glue or shoe goo.
3. Pull the center (red) pin and wire from the ESC receiver connector. This disconnects the built in BEC from the ESC. You don't need it, it is only powering the motor. Make sure to tuck it away with heat shrink tubing. You will need it if you need to re-program the ESC.
Here it is ready to go:
I made a mounting plate for the APM using 5mm plywood, which I assume is 1/4" thick. I cut it 45 x 80 mm. I mounted my APM on sorbothane and secured it to the gel pad to the plywood plate with Welder's glue. I bought the Welder's glue from Lowe's, but if you can't find it, Amazon has plenty.
The APM mounted on the plate:
(Pictured are the stock cables to the GPS. I will be using the 30cm cables for the real build)
A note on Welder's Glue: it is contact cement. Lightly cover each surface you wish to bond and let them partially dry for about five minutes. Put the two surfaces together and POW, it is stuck. I will also use Welder's Glue for assembling the foam air frame and building a super trick access door in the fuselage.
In Part Two of the build, we modify the airframe to accommodate the APM. We also make a really cool access panel to access the ports and USB hub of the APM.
Comment by Dave Smith on January 2, 2014 at 7:13pm
I am new to "blogging", so bear with me. I thought it would be easy to add a second part, but it looks like I need to post a new post when the airframe comes in. I don't want to bother the Mods too much.
Comment by Chris Anderson on January 2, 2014 at 7:29pm
Great build log. I'm still a big fan of the Bixler, which I think is absolutely the best first UAV platform. It may not carry much, but it's easy to launch, easy to pack and cheap to fix.  I think I'm on my fourth!
Comment by Dave Smith on January 2, 2014 at 7:37pm
$42 for a replacement airframe is hard to beat! It flies very nice in stabilize mode for a newbie, and has very aggressive control surfaces for a more seasoned pilot. I will probably use it to teach my daughter to fly.
Comment by Gary McCray on January 2, 2014 at 7:38pm
Hi Dave, Would you mind if I made a wiki "Build" page for the APM:Plane wiki out of this and your succeeding additions.
This should be a really valuable article to introduce sound practices to our users.
Best Regards,
Gary
Comment by Dave Smith on January 2, 2014 at 7:41pm
Wow, that would be great. Is there anything I need to do on my end, other than add to the blog?
Comment by Gary McCray on January 2, 2014 at 8:12pm
Great,
No just add to the Blog, I'm pretty fast these days on making wiki pages.
I'll put in a link once I get the first pass going and you can let me know anything you'd like changed.
Best,
Gary
Comment by Gary McCray on January 2, 2014 at 10:06pm
Hi Dave,
Your Wiki page is here: http://plane.ardupilot.com/wiki/a-high-quality-bixler-1-1-build/
I changed some of the text to make it more instructional and less conversational and to reflect some common practices.
Please post your updates here so I can finish it up with the rest of your build.
Best Regards,
Gary
Comment by Gary Mortimer on January 2, 2014 at 11:55pm
Good job Gary! I have two Bixlers that my son flexes the wings on frequently I am amazed the abuse they take and as has been said for $42 hard to beat. When I put an APM in one of them it took me an hour and a quarter. Most of the time spent because I had forgotten how to program my TX.
Comment by Dave Smith on January 3, 2014 at 5:10am
The wiki is nice! Good job.
Comment by titeuf007 on January 3, 2014 at 6:45am
great!
now you have just to add you setting on you great wiki page to be perfect
nice mount
Comment
