What is an amateur UAV?
A Unmanned Aerial Vehicle (UAV) is an aircraft that has the capability of fully autonomous flight, without a pilot in control. Amateur UAVs are non-military and non-commercial. They typically fly under “recreational” exceptions to FAA regulations on UAVs, so long as the pilots/programmers keep them within tight limits on altitude and distance. Usually the UAV is controlled manually by Radio Control (RC) at take-off and landing, and switched into autonomous mode only at a safe altitude.
What do I need to make one?
- An RC plane
- An autopilot
- Optional: a useful “payload”, such as a digital camera or video transmission equipment
What type of autopilot should I get?
Autopilots in the amateur category typically fall into two categories: thermopiles or inertial measurement units (IMUs). Thermopiles are infrared sensors that measure the temperature gradient between the sky and the earth and use that to stabilize the aircraft. IMUs use accelerometers and gyros to do the same thing.
Thermopiles:
- Pros: inexpensive, easy to program
- Cons: less effective in certain weather conditions, such as snow and fog/rain
IMUs:
- Pros: can operate in any weather conditions, very accurate
- Cons: relatively expensive, hard to program
Leading autopilot examples:
Thermopile-based autopilots:
- AttoPilot ($800): Very powerful commercial autopilot, closed source
- ArduPilot ($24.95 + approximately $180 in additional parts such as GPS module and sensors): Arduino-based open source autopilot. Easy to expand and modify, but requires some soldering
- Paparazzi ($425): Powerful, but somewhat hard to use open source autopilot. Requires Linux and some programming skills.
IMU-based autopilots:
- UAV DevBoard ($149; also requires $60 GPS module): Open source autopilot development board and code, designed for flexibility and expandability, but not yet a full autopilot with waypoints and ground station. Best for flight stabilization and return-to-launch.
- Procerus autopilot ($5,000): powerful commercial autopilot, requires ground station equipment
Okay, what's next?
Follow
this flowchart (sample below) to decide how to proceed!
Join this Ning Network
