Adding 3DR radio telemetry to the Quanum Nova APM-powered copter
I just got a Quanum Nova, which is a fantastic APM-powered copter that in many way outperforms the DJI Phantom for less than $300.  Although it's capable of full autonomy, just like any other ArduCopter, the one thing it's missing for easy field mission planning and DroidPlanner compatibility is telemetry.
In this great tutorial, Jean-Louis Naudin shows how to add that:
Here an explanation for connecting the real time telemetry to the CX-20 or to the Quanum Nova
The telemetry port is located on the I/O board of the APM (the second board at the bottom and pluged to the main CPU board) where all the I/O plug are connected. The telemetry port is fully compatible with all the telemetry transmitter (3DR and all the compatible boards) and also with the Bluetooth boards commonly used with the APM boards.
alt text
Below the pinout which shows the telemetry port I/O (back to the I/O board).
Note from the comments: depending on which radio you're using, you may have to reverse the TX and RX lines. Dmitry in the comments reports: "You must connect RX from the radio to TX on the APM! And vice versa for Radio TX. So I've changed green and yellow wires and it works!"
 alt text
sold 4 cables on the telemetry ports alt textthen protect the connections with hot glue alt text
Check the functioning alt text
The 4 pins telemetry plug is installed on the back of the fuselage alt text
Check the connection (at 57600 baud) with the mission planner or the Droid Planner 2 alt textalt text
Then, you may enjoy to use the telemetry... alt text
NEXT CHAPTER: Full autonomous mission with the Cheerson CX 20
Comment by Scott Penrose on June 15, 2014 at 4:16am
Images are broken, link to tutorial is broken. Tried finding it, no luck.
Comment by Stuart Brookes on June 15, 2014 at 4:25am
worked for me this morning
Comment by Jean-Louis Naudin on June 15, 2014 at 6:50am
The link to the Telemetry connection tutorial is pointed below:
Jean-Louis
Comment by Ruwan on June 15, 2014 at 9:17am
I've updated the tutorial link with the link provided by Jean-Louis Naudin.
Comment by Don H. on June 15, 2014 at 9:18am
Has anyone setup OSD yet?
Comment by Rolf Stefani on June 15, 2014 at 9:37am
Jean-Louis, I have followed your github posts on CX-20 with great interest. Prompted me to acquire my own QNova from HK. Flies great and videos from my mounted SJ4000 are fantastic.
One question about mounting the telemetry radio. Do you connect the wire that comes from the radio tx pin to the rx pin and the radio rx to the tx on the FC board? Like a normal serial Crossover type connection. Thanks for you great info.....
Comment by Jean-Louis Naudin on June 15, 2014 at 12:57pm
@Rolf: Yes, the Radio Tx is connected to Rx pin of the APM and the Radio Rx is connected to the Tx pin of the APM.
You will find some additional infos about the 3DR telemetry at:
http://plane.ardupilot.com/wiki/common-using-the-3dr-radio-for-tele...
Regards
Jean-Louis
Comment by Scott Penrose on June 15, 2014 at 1:56pm
Awesome ! Got mine last Friday and have flown it over the weekend a few times. Very stable easy to fly. Looking forward to adding telemetry :-)
Comment by hotelzululima on June 15, 2014 at 9:07pm
wow those went out of stock quick :)
    hzl
Comment by Chris Anderson on June 17, 2014 at 4:07pm
I just did this with a Bluetooth module (using this tutorial), which has the advantage of being entirely internal so it's invisible. Works great! I'm getting 100m range! This is now the perfect low-cost FollowMe copter.
Comment
