Hello all, I've been toying around with the MikroKopter Hexakopter as a tool for aerial mapping and photogrammetry. After a few weeks of learning the ins and outs of the system, I finally had some time on the weekend to test the system for mapping.
In short, we placed Ground Control Points (GCPs) around a man-made ponding area at roughly ten meter intervals (~40 x 30 m in total area). The GCPs were shot in with a deferentially-corrected GPS (~0.1 m horizontal and ~0.2m vertical resolution) and with a Total Data Station (>0.03m vertical and horizontal resolution). We then flew the Hexakopter at 40m above the ground surface in an east-west grid pattern with a photograph being taken straight down every 10 m or so. The camera used was an off the self Canon A540.
The photographs were processed to remove most distortion and dropped into a photogrammetry program. A 0.05 m resolution DEM and 0.02 m photomosaic was created from 22 images. It took about two hours to collect the photographs, and shoot in the GCPs with both the DGPS and TDS. Processing of the imagery was nearly flawless and took about two hours as well. This time can probably be reduced to an hour or less.
Compared to doing this same process with a kite or blimp, I am very impressed with the Mikrokopter (and multi-copters in general) as a platform for high resolution, low altitude mapping. Let me know what you think.
Over the next few weeks, I'll be testing the same process in at a couple of archaeological sites in the southwestern US. I'll share some of those results when they are complete.
Can't wait to play with the truly opensource Ardupilot!
-Mark
Comment by brakar on June 8, 2010 at 10:49am
Comment by abey on June 8, 2010 at 12:50pm
Comment by Bart on June 8, 2010 at 1:29pm
Comment by Peter L on June 8, 2010 at 2:47pm
Comment by Tom Verstappen on June 9, 2010 at 1:33am
Comment by Roberto Hawkowski on June 9, 2010 at 5:35am
Comment by Mark Willis on June 9, 2010 at 8:08am
Comment by Rory Paul on June 9, 2010 at 8:44am
51 members
133 members
1298 members
249 members
Powered by
