I'm pleased to announce that we've joined forces with the other Arduino-based powerhouse in the aerial robotics world, the AeroQuad quadcopter team, to extend the ArduPilot platform to whirlybirds of all kinds. The project, called ArduCopter, will use the ArduPilotMega and IMU shield hardware along with a low-cost custom platform that will be available commercially to provide a full quad UAV with both stabilization and GPS waypoint navigation. It builds on the awesome work of Jose Julio in ArduPilot quad development, with the excellent full-systems integration of the AeroQuad team. We expect that first code and hardware will be available this summer.
Another team is also extending this to traditional helis, starting with the Trex 450 heli (and its equivalents), which should be ready for release this fall. Along with Blimpduino, this should make for 100% coverage of all aerial robotics platforms on the Arduino platform, with shared libraries and ground stations across projects. Go Arduino!
We'll be setting up a proper microsite here, along with dedicated tab, for the project in the next few days.
If you haven't already seen this preview of what the ArduPilot/ArduIMU combo can do with quads, check this out:
And here's the impressive work of the AeroQuad team:
Hey guys, as many of you know the AeroQuad has teamed up with DIY Drones on developing a very full featured multicopter! Chris from DIY Drones has proposed the name of this new effort to be called the ArduCopter! It will be based on the ArduPilot Pro Mega (APM) and the APM sensor board currently nicknamed the Oil Pan. Here's an initial feature list and software road map. Please chime in! Your input is valuable! I'll keep updating this front page until we agree on the first version of the ArduCopter's capabilities.
ArduCopter Feature List
6 Degree of Freedom IMU stabilized control
Gyro stabilized flight mode enabling acrobatics (loops and barrel rolls)
GPS for position hold
Magnetometer for heading determination
Barometer for altitude hold
IR sensor integration for obstacle avoidance
Sonar sensor for automated takeoff and landing capability
Automated waypoint navigation
Motor control using low cost standard PWM Electronics Speed Controllers (ESC's)
On board flight telemetery data storage
Mounted camera stabilization capability
Wireless command & telemetry for long distance communication
Capability to fly in "+", "x", hexa and octo configurations
Battery level detection
User configurable LED flight pattern
Capability to use any R/C receiver
ArduCopter Configuration and Ground Control Software
Realtime graphs of flight data
GUI for configuration of PID and other flight parameters
On Screen Display integration
Waypoint programming using Google Maps
Mixertable view to auto configure "+", "x", hexa and octo configurations
Software Roadmap
Initial baseline using Jose Julio's v3 software
Provides absolute angle PID flight control
Obstacle avoidance
Waypoint navigation
Generalize basic ArduCopter functions (ie. Separate PPM receiver input and motor control functions into separate libraries. Allows future coding of PWM vs. I2C ESC's)
Emphasis on developing new capability into easy to use C++ libraries
Integrate user defined EEPROM storage capability
Develop/optimize AeroQuad serial real-time command/telemetry for ArduCopter
Integrate AeroQuad Configurator for external software configuration of ArduCopter
Rename Configurator to Ground Control Station and integrate graphical programming of waypoint navigation
Integrate AeroQuad rate PID control
Integrate mixertable configuration for multicopter configurations
Integrate AeroQuad camera stabilization
Integrate I2C motor control
Develop capability to wirelessly control ArduCopter directly from Ground Control Station (USB joystick controller from laptop or through waypoint programming)
Comment by Neil Baker on October 3, 2010 at 1:50pm
I have been tring to get my roll and pitch gyros to work in the configurator. Followed the setup correctly including initializing the eprom. Everything else works fine. Re-downloaded the alpha software and started fresh but still no success. Fired the quad up in stabilize and acro and they definatelly arent working. Must be something small that I am missing. Anybody have any ideas? I attached the serial stream below with me moving the quad all around. Cant remember where in the line the gyros are though.
Not sure why we call it "calibrating the ESCs". What we are actually doing is configuring or setting them up properly for use with the multikopter and that includes defining minimum and maximum throttle value, but can also include such things as correctly setting the digital switches for low battery cut-off value and type, battery type, braking, etc. Wonder wheterh it would be a good idea to develop a small Arduino Mini Pro (or similar) application for setting up and testing the most popular ESCs (and testing motor/prop combinations). That might be more flexible than trying to do it all through the Configurator and APM. Since I have a couple of arduino pros lying around I-ve certainly been using that approach for testing I2C converted ESCs on a simple thrust testbench instead of mounting everything on a multikopter and then testing with the potential risk of something unexpected happening and causing damage.
Just another thought: This blog format isn't too convenient to group information in. As ArduCopter and AeroQuad are closely linked, would it not make sense to set up one or two separate areas with the AaroQuad forum where threads specific for the ArduCopter could be grouped ?
Arthur, the problems is that everyone is just using this blog as a catch-all for ArduCopter discussion, rather than starting threads in the discussion forums as they should. The ArduCopter forums are here. I'm going to close comments in this thread to keep it from metastatisizing further ;-)
Masterbaker: you may have a bad board (roll and pitch are the same gyro chip and it may have a loose connection). I'd return it to be checked out and reflowed if necessary.
Season Two of theTrust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.
