ArduPhantom: APM ArduCopter in a DJI Phantom Airframe
Figure 1: ArduPhantom Night Flying
The DJI Phantom has some nice air frame features: A sturdy plastic injection molded polycarbonate enclosure that keeps out light rain and resists hard impacts very well; Nice motors with simple, easy to use prop-mounts that are very unlikely to come loose in flight or get bent or broken in a crash; and very light-weight ESCs that have super bright LEDs on them for easy visual orientation at great distance, and superb night flying (Figure 1).
I also wanted a very small, lightweight, and extremely rugged FPV platform that I could carry in my backpack when I go hiking. The DJI Phantom air frame seems perfect for this, as the propellers are extremely easy and fast to remove, and once removed the rest of the aircraft can be stuffed in my backpack as is, and is sturdy enough to not worry about it being damaged during the trip.
But, since I'm a fan of ArduPilot, and like to be able to perform complex auto missions and make modifications to the code, I decided to build a DJI Phantom air frame with an APM flight controller. The result was very successful, and I encourage you to do the same, following the instructions below.
Materials
For this build, you will need the following parts. Fortunately, the DJI replacement parts needed can all be purchased quite cheaply. My budget for this entire project was about $600.
1x DJI Phantom replacement case kit
1x DJI Phantom replacement screw kit
1x DJI Phantom connectors kit
2x DJI Phantom ESCs (green)
2x DJI Phantom ESCs (red)
4x DJI Phantom motors
2x DJI Phantom props (set of 1 CCW and 1 CW)
1x DJI Phantom landing gear
1x APM 2.5
1x 3DR Power Module
1x 3DR GPS module
Power System Wiring
First you'll need to mount the ESCs and motors in the case, and wire up the ESCs to the output side of the power module. When mounting the ESCs, be sure the green ones are at the front end of the aircraft (the battery door end), and the red ESCs in back. If you put the red ESCs in front instead, then the signal leads won't reach, because they are of different lengths.
There is not much space inside the case for a lot of wiring and connectors, so I just cut off the XT60 connector from the output side of the APM power module, and soldered the connection directly, insulating with heat shrink of course. If you plan to use an internal battery, make sure the wiring doesn't cross over the central area where the battery goes, because it will snag on the battery when you take it in or out, and it's already a fairly tight fit for the battery as is.
Also, be sure to keep all the wiring as low in the bottom of the case as possible, so the magnetic fields from high-current wires will not interfere with the autopilot's magnetometer (Figure 2).
Figure 2: Power Module and Power System Wiring
Mounting APM, GPS, and RC Receiver
At first I velcro mounted the autopilot, GPS, and receiver to a thin wood plate which I screwed on to the four screw bosses protruding from the case bottom. This held it high enough above the power wiring below to avoid magnetic interference. However, I found that this piece of wood was basically a sounding board for vibration. Even adding foam between it and the autopilot wasn't enough to reduce the vibration to a reasonable level to get good accelerometer readings (Figure 3).
Figure 3: How NOT to mount your APM
Later I found that a soft plastic cottage cheese lid made of Low-Density Polyethylene (LDPE) is a great way to mount the APM, since the soft flexible material helps to dampen vibrations (Figure 4).
Figure 4: APM mounted on LDPE food lid greatly reduces vibration
Once you get the case on you won't want to remove those 16 screws every time you need to upload the latest version of ArduCopter, or download a flight log. So you should probably make a short USB cable that permanently connects to the APM, as shown connected in figures 3 and 4 above.
LED Connection
You won't be able to see the status of the armed and GPS lock LEDs once the APM is enclosed in the case, so you'll want to connect a couple external LEDs that you can view through the tail light port on the Phantom case. Connect one LED to A4 and one to A6 (you can also connect a buzzer to A5 if you want). Signal goes to the + side of the LED, and ground to the - side. Remember to include resistors in series with each LED to drop the voltage to the proper level for the LEDs you are using (Figure 5).
Figure 5: Armed and GPS fix LEDs visible through tailight port
 You'll also need to go into Mission Planner and change the LED_MODE to 11 (the default is 9 for some reason).
Final Assembly
You can now put the top of the case on (attached with the twelve M2.5x5 and four M2.0x8 screws from your screw pack). Once you calibrate and configure everything in Mission Planner then you should be ready to bolt on the props and go fly (Figure 6)DJI phantom
Figure 6: Ready to Fly
Flight Testing
I added a GoPro, a 5.8 GHz video transmitter, and a 3DR telemetry module for some FPV flying during a Sunday hike in the mountains. Here's the results of the first test:
It flies very nicely, even in auto modes. The main issue is shakiness and vibration of the recorded video. Hopefully I can reduce that with some tuning, better camera mounting, and perhaps stiffer props.
Comment by AKRCGUY on April 9, 2013 at 5:53am
Great How To video!
Comment by Kevin C. Carroll on April 9, 2013 at 6:11am
Thanks and very well done. I was just wondering about using some tin'd metal mesh to reduce the field issues (if there are any) also.
Comment by David Dewey on April 9, 2013 at 6:16am
Hi Kevin, I don't think there are any field issues, because the compass offsets look good (-53.0150, 1.0115, and 4.7202 after the latest flight), and it seems to always turn directly to the next waypoint, so compass must be working well.
Comment by Duran - ALTI on April 9, 2013 at 6:19am
Great post, I actually did this a bit further down the blog :)
http://diydrones.com/profiles/blogs/what-a-phantom-should-look-like...
Comment by David Dewey on April 9, 2013 at 6:24am
Hi Duran, thanks for pointing that out, yours does look very nice. I think my version may be cheaper though, since you don't need to buy a whole Phantom to start out with, just a few of the cheap replacement parts they sell.
Distributor
Comment by Dany Thivierge on April 9, 2013 at 7:20am
hey I like what you did there!  nice.
Comment by HeliStorm on April 9, 2013 at 7:23am
Very nice. Would you ever consider doing a build for someone?
Comment by David Dewey on April 9, 2013 at 7:26am
Hi HeliStorm, yes, if it was an interesting build that I could learn something from doing.
Comment by HeliStorm on April 9, 2013 at 7:46am
I like the frame of the Phantom, but feel the actual quad could be limiting. I like what you have done here, but my build experience with quads is limited.
Comment by HeliStorm on April 9, 2013 at 7:53am
I have entirely rebuilt a few single rotor CP helicopters, so I am not a stranger tools and soldering irons. I am just a stranger to quads.
Comment
