After nearly six months of development from first public alpha, hundreds of hours of flight testings and countless bug fixes, I'm delighted to announce that ArduPilot Mega 1.0 is now out of beta. This code is solid, should run pretty much out of the box and has been tested on more than 30 different airframes, to say nothing of countless flight simulator hours. This is almost certainly the most complex Arduino program ever written, and takes the Arduino hardware further than anyone thought was possible.
Between the APM code and the Libraries, there have been more than 3,000 commits to the SVN repository, which is just one indication of the amazing amount of work that's gone into this. Huge thanks to the team leaders: Doug Weibel, Jason Short, Michael Smith, Michael Oborne, James Goppert, Benjamin Pelletier, and Paul Mather, with special library assistance from Jani Hirvinen, Jose Julio and Randy Mackay.
To get started with APM 1.0, we highly recommend using the hardware-in-the-loop simulator using the Mission Planner and the excellent Xplane Flight Simulator. Hugely fun to program missions and watch the planes perform them perfectly, hands off.
Included in APM 1.0:
  • Flight modes: Manual, Stabilize, Fly By Wire, Auto, RTL
  • Mission Scripting commands: Navigate to Waypoint, Loiter X turns, Loiter X seconds, Loiter (indefinitely, good for ending mission), RTL, Land, Takeoff, Landing Options, Delay, Reset index, Go to index, Change throttle, Change airspeed, Reset home, Change PID gain, Set relay, Set servo
  • Hardware support for airspeed sensor, Xbee telemetry (one-way), battery monitoring
  • The awesome Mission Planner utility
  • The equally awesome HappyKillmore Ground Station
Coming in APM 1.1 (probably in about a month):
  • Mission Scripting commands: Climb (rate based), Get Variable, Send Variable, Telemetry, Change radio trims, Change radio mins/maxes.
  • Hardware support for magnetometer
  • Two-way telemetry and in-flight gain and command sending
  • Support for the MavLink com/telemetry protocol.
The work to bring APM to maturity will also pay dividends for the rest of the Ardu* family of autopilots and UAV systems, which share the same libraries. This includes:
  • ArduCopter (quad) will be moving to 1.0 (codename NG) later this week, and a 1.5 version (codename ArduCopter Mega) that syncs up with the rest of the APM family, including the Mission Planner and Ground Stations, will be out in beta in a about a month.
  • ArduCopter (heli) is already out in beta and flying. If you've got a Trex 450-style heli, please give it a try and let us know how it's working for you.
Distributor
Comment by Martint BuildYourOwnDrone.co.uk on December 13, 2010 at 1:24am
Hi Chris, Great to see the new code is ready to go! If the weather holds I will use it a little later on today, it is amazing how far you all have brought this project, I was only reading this post: http://diydrones.com/profiles/blogs/705844:BlogPost:16007 a few days back. Thank you all for you hard work! Regards
Martin
Comment by Sverre Faureholm on December 13, 2010 at 2:24am
Great news.
Does anyone know of a way to connect an OSD board to the APM?
The way I see it, this system could outperform any of the existing OSD systems on the market, because the APM is very integrated with almost everything on-board:GPS, Barometer, airspeed, IMU (for showing artificial horizon), voltage + current sensors would be quite easy to implement.
Regards
Sverre
Comment by Colin on December 13, 2010 at 3:18am
Chris,
In version 1.1 you say "Two-way telemetry and in-flight gain and command sending" will be coming. What protocol will this be using? GCS_PROTOCOL_LEGACY?
Thanks,
Colin
Comment by Jonas on December 13, 2010 at 5:05am
congratulations and celebrations to all who made it happen!
Comment by Paul Marsh on December 13, 2010 at 5:31am
Congratulations to the team!  Well done.
Comment by Rana on December 13, 2010 at 5:39am
Big big conratulations to the development team: Doug Weibel, Jason Short, Michael Smith, Michael Oborne, James Goppert, Benjamin Pelletier, and Paul Mather.
I would like to specially thank Jordi, for his incredible contribution in the project and for the PCB design !
Best Regards
Rana
Comment by ruudh on December 13, 2010 at 5:48am
Excellent job!
Is there also an address in Europe for buying APM mainboard, IMU shield, pins, connectors, etc?
Comment by Chris Walsh on December 13, 2010 at 5:56am
like
Distributor
Comment by Martint BuildYourOwnDrone.co.uk on December 13, 2010 at 6:14am
@ Ruudh
Take a look here for Euro parts, I have used them before, very good :)
Comment by Rana on December 13, 2010 at 6:40am
ArdupilotMegaPlanner_0.4.12 crashing in XP, service pack 3
Comment
