Ok, here is my Tri-Copter frame for ArduCopterMega, thanks to Jason ;)
I did some mixing here :)
Original frame design is from rcexplorer's tri-copter:
Center plate is laser-cut from 3mm plywood, there is 2 bottom side options:
One to attach t-rex 500's landing skids
For tail i used this servo
here is a long video to waste some time ;)
9X4.7 APC props (all CCW).
15X15mm 1mm thick 50cm long Aluminium arms...
center and servo mount (for 15X15mm arms)
the weather is bad here :(
so no videos for now :(
Good flying to ALL !!!
next will be that:
(Sandro thanks for the motors/props/esc ;) )
yes i found it already. However i must first get the magnetometer module to draw forward and test ACM.
I even didn't try APM in my airplane ;o(,
Thanks for navigation.
Yes, thats how the Mikrokopter has it..
Here you can see it quite good: http://gallery.mikrokopter.de/main.php/v/uploads/mischer+X8.jpg.html
How about a extra page in the configurator, where you can ajust the motors...
Daniel
How should I implement the speed differential top to bottom. Is it a scaled value like 80% of the top?
Let me know and I'll add it.
Jason
This is how ACM output to motors,..
In CLI chose frame type 'tri' in setup menu...
There is a readme in ArduCopterMega folder, with all the comands :)
Max, that is so interesting with the Y6, good to see progress on that.
I am in the process of building up a heavy lift Y6-arducopter-electronics are sitting waiting here ;-)
Looking forward to hear about your Y6 progress...
Good to hear it will have adjustable motorspeeds for top and bottom..
Regards
Daniel
Max thanks a lot for wiring diagrams update. Anyway you suggest left ESC connect to output 2 (APM 1.4) and rear ESC and servo to output 4 and 7 respectively.
I would expect rear ESC connected to output 2 just (for elevator) and servo to output 4 (rudder). I thought so because of APM in airplain configuration do this way. Are those APM outputs remaped in arducoper configuration?
Hi Max,
Tri-copter? Not yet.
I will probably try to make a 3D printed quad/hexa frame first. :P
(That 3D print idea is sticked on my mind...)
@Palo
Jason is updating ACM code daily,it can be buggy some times :), IT'S ALPHA CODE, be ready to crash :) or test it many times on the ground :)
Go to http://code.google.com/p/arducopter/wiki/Quad_Radio and just connect it, as i updated in the post.
ACM is in HERE.
@Jason
Flight in the video, is on ACM default PID, don't see any reason to change it, maybe speed it up a bit on the YAW... response ?
@Daniel
Jason is the boss on this one ;)
but yes, i did some testing on the Y6, it was OK.
and it definitely will have top/bottom motors speed adjustments, Jason ? ;)
@Sandro
Thanks, Man. Are you starting to build one ? :)
In the CLI you go to setup and type "frame tri". That's it.
Y6 is coming. I'll wait until Max is ready to help test.
Jason
