Very cool hack by a university team, using Android and Arduino. From Makezine:
The vehicle is a creation of University of Gothenburg student Dimitris Platisand his team of Makers — Yilmaz Caglar, Aurélien Hontabat, David Jensen, Simeon Ivanov, Ibtissam Karouach, Jiaxin Li, and Petroula Theodoridou — who collectively go by the name Team Pegasus. The team’s work is impressive, they’re GPLv3 licensed, and their documentation is quite good. The project is ripe to enable other interested Makers to jump right in and create their own fork of the project.
Originally, Platis’ class assignment directions suggested using a single-board computer, webcam combine, elaborate simulation software package called OpenDaVinci, and an aesthetically unattractive chassis, all of which he wasn’t too excited about. So, he and the team decided to dump the suggested components and solve the problem set using their own approach.
Here’s an overview of the project.
The electronics layout inside the car should look pretty familiar to anyone who has used Arduino to prototype a project. The Arduino MEGA connects with three ultrasonic sensors, two of which are mounted on the front of the car and one on the rear bumper. Three IR sensors also wire to the MEGA and are deployed in a similar fashion. A gyroscope and 9 degree-of-freedom inertial measurement boards round out the sensor package, but are placed within the chassis of the vehicle.
Steering directions are transmitted from an onboard Android phone running vision processing and transmitted over Bluetooth, and the electronic speed control (ESC) and Adafruit motor shield handle the car’s acceleration (not shown).
Finally, and also not shown in the layout, is an ATtiny85 microcontroller that is programmed with its own sketch to handle LEDs control for such are things as breaking, turning, and illuminating the roadway.
The code leverages AndroidCar.h, a custom library built by Team Pegasus, and polls sensor data on the car, which is then sent via Bluetooth to the onboard cellular phone.
Then, the API handles the transmission of steering commands from the phone’s computations and alters the servo position. To learn more about the API, check out the Smartcar Core example sketches. For documentation on the code that glues the Arduino code with the Android phone, you want to check out the Android-Car-duino repository. And for an overall approach to adapting this set of libraries to your own vehicle this wiki is for you.
if i have to do the same ... wat should i do?? can uh help me out ??
This was very cool. Nice work.
Thanks, Grant.
@Chris,
Back in the mid 2000s Parallax had a self parking BoeBot that could drive slightly past an open spot between two BoeBots and back into and park itself between the two BoeBots. This was all done with a Parallax BS2.
TCIII AVD
