Comment by Víctor Mayoral on August 3, 2014 at 4:19pm
This seems like an extended copy of the crazyflie. Did the autoquad guys reach an agreement with the  http://www.bitcraze.se/?
As far as I know, even though the provide the design files, they quite protective when it comes to use their design comercially.
Comment by armen t on August 3, 2014 at 5:22pm
Alright ill bite. How much for the on live video, Bluetooth, osd, etc?
Comment by Jack Crossfire on August 3, 2014 at 5:43pm
The 407 is obsolete.  You need to be using the 427.
Comment by Max Levine on August 3, 2014 at 5:44pm
Comment by Bill Bonney on August 3, 2014 at 5:58pm
@Jack: but looking at digikey you can save almost $3 on the BOM (based on a single unit price) more if you buy multiples. It may be better, but what does 427 offer over 407 that make it a must? It's not always about the latest, but being successful in creating a business model that succeeds.
@Max: was the big octo flying with the same controller?
Comment by Bill Nesbitt on August 4, 2014 at 2:03am
Jack - I'd normally agree, but there is no 64pin version of the 42X.  The only real constraint of the 40X is the RAM and that's not quite a problem for AQ yet.
Comment by robert bouwens on August 4, 2014 at 4:17am
a small copter is on my list since a longer time.
i hope the aq micro will be available soon.
Comment by joebar.rc on August 4, 2014 at 7:53am
@Victor,
Besides the obvious shape and the use of a stm32 based MCU it can hardly be called a copy.
The m4 is stm32f405 instead of 103, use of different IMU sensors, use of a GPS module, CAN bus, on board spektrum receiver etc etc.
I did personale never seen that FC you referred too, looks nice indeed but if you think a design change to another mcu, different IMU, gps is merely an action of drawing some lines?.. It's not. This is the design of Bill and Steve and not a copy.
The m4 is carefully designed since last year and already iteration r5 before it is released soon
Comment by joebar.rc on August 4, 2014 at 8:07am
@robert
It will :). At the maker fair Hannover already dozens where on display and flying. A minor change was needed for the onboard spektrum receiver so the upcoming production version is without physical errors.
The best feature IMHO of the m4 is that it is scalable, maybe the first FC that can be scaled from nano to full size up to 16 motor multirotors(CAN based ESC's) or using a specialized motherboard with CAN to pwm mapping. Plugging in a 2cm board on top of the m4 will also make a couple of normal pwm ports available. So it can grow with you
Comment by John Church on August 4, 2014 at 9:06am
Hey, Bill, what's this quatos stuff? I can't find much about it over on autoquad.
Comment
