BLHeli for Atmel and Silabs, united by BLHeliSuite
Now the BLHeli firmware/software suite is available also for Atmel ESCs.
The ESC firmware source code is published here: https://github.com/bitdump/BLHeli
The BLHeliSuite PC software can be found here: http://www.helifreak.com/blog.php?b=2162
The Atmel version of the ESC firmware is a direct conversion of the current Rev11.2 SiLabs version.
Comment by Juan Carlos Hdez on April 8, 2014 at 2:24pm
What improvements has over the Simonk firmware?
Comment by Nicholas Witham on April 8, 2014 at 3:56pm
Any good links to how to flash each version?
Comment by Juan Carlos Hdez on April 8, 2014 at 4:20pm
Comment by Richard (DK) on April 9, 2014 at 5:55am
Comment by Artem on April 9, 2014 at 1:47pm
out of my experience Blheli just shines on k-foce 40a  ESCs on 380kv 40mm multistars on 6s and 1555 props..
Comment by Francis German on April 13, 2014 at 3:27pm
Has anybody tried the closed loop with or without dampening on multirotors, yet?
Will there be a possibility to "learn in" the motor like on esc32?
Comment by Michell E. on October 23, 2014 at 8:19pm
Be careful, my ESCs (Plush 6A) with BLHeli work fine, except one that from time to tim just stops working (no beeps but BEC still gives voltage) and no matter what you do it won't work again until I reflash it. Bug perhaps.
Comment by andres on March 27, 2015 at 10:51am
Hola solicito de su ayuda lei su post pero los link que pone para bajar el programa y el firware no funciona y si me puede ayudar ya que tengo los esc red brick de hobbit king y el arduino uno pero no he podido flashearlos esc para quadcopter no puedo bajar el blhelisuite y como se conectan los esc ya que los conecto al arduino uno y me sale siempre CONECTION TO TARGED FAILED
Comment
