Correct Blimpduino LED/motor/servo behavior
The correct Blimpduino behavior modes are as follows.
First power-up of board, straight from the factory:
Red Power LED: On
Four green LEDs Flashing in sequence, then altogether, then in sequence again:
Blimpduino code loaded, RC receiver plugged in. Power on/calibration sequence:
Red Power LED: On
Four green LEDs 1st: flashing in sequence. Then: North LED only while reading RC. Then: alternate N&S, E&W to signal RC control
Vectoring servo: Responds to RC stick control
Motors: Speed up when channel 2 stick is pushed up, slow down when pushed down. Channel 1 stick controls which motor spins faster
Autonomous mode (RC not connected) startup:
Red Power LED: On
Vectoring servo: Moves up, level and then down while calibrating US sensor. Then tilting up or down for altitude hold depending on whether the board is above or below initial height
Motors: Should spin. Direction/speed depends on what the sensors are seeing
Autonomous mode (RC not connected); beacon present and visible to board:
Red Power LED: On
Four green LEDs Light up in direction of beacon
Vectoring servo: Then tilting up or down for altitude hold depending on whether the board is above or below initial height
Autonomous mode (RC not connected); beacon not present and or not seen by board:
Red Power LED: On
Four green LEDs Off
Vectoring servo: Stationary, usually titled down
Motors: Should spin. Direction/speed depends on altitude
Battery low:
Red Power LED: On
Four green LEDs All flashing
Motors: Off
Comment by Mitch Patenaude on June 20, 2009 at 8:47am
Just to clarify, until the blimpduino code is loaded using the FTDI cable, the RC mode will not work with the code that is loaded at the "factory". Is that correct?
Comment by Chris Anderson on June 20, 2009 at 9:17am
Correct
Comment by david williamson on July 22, 2009 at 2:17am
because most domestic environments are very cluttered, wouldn't the ultrasonic eye be better employed using the ceiling as a height datum? What about unsoldering the ultrasound transducer & putting it on top of the blimp facing upwards then removing the altitude moter & sticking it back on upside-down?
Comment by Neal McBurnett on January 9, 2010 at 12:03am
That's a real problem and a clever idea, but I bet it is a hassle (and unattractive) to put the sensor on top and run all the necessary wires.. I also wonder if e.g. my ceiling (with bumpy textured plaster) would be a good enough surface to measure against.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
