Well I feel better now. I'm always a little nervous to fly a new ship until the first crash. You never know how she'll deal with adversity.
I was flying FPV in loiter at ~15m when it suddenly pulled hard right and back making a nice arc into the ground at about 20kph according to the telemetry log. The current jumped from the ~30A normal to over 60A in the few seconds of the death plunge. When I got there the motors were spinning and wouldn't react to transmitter commands including disarm. All the props were broken of course.
Looked through the logs a bit, but I can't tell what happened. If anybody cares to take a glance and give me some insight, I would be very grateful. I don't mind when things go terrible if I can at least understand why it happened.
The damage seems to be limited to a couple of cracked arms and a few other frame bits. The GoPro was fine thanks to the waterproof housing. Not even a broken antenna on the 3dr radio or video Tx! I'm taking it all apart tonight and checking the electronics, they got covered in snow, but no physical damage that I can see so far. I'll upload some pics once Iphoto stops crashing every time I try to get them off my camera. There must be weird solar weather or something going on today, I've never had a problem getting pics off of my camera before, really strange...
I'll have to upload my tlogs from the windows machine, just a minute.
Comment by Emile L. on January 18, 2013 at 6:23am Great gimbal control!
I have had similar spontaneous response when in loiter with APM 2.0. Log review showed a GPS change to the mid Atlantic from western Canada. It returned within a couple of seconds but took the quad for a little ride.
Emile L.
I'll have a look at your logs if you post them here.
As Emile says, your gimbal was working well at least!
Perhaps we need some more checks around ridiculous positions from the gps...
Hi Randy, I've seen this as well, exactly as Emile documented... but I was not flying, just connected to Mission planner testing the products before shipping to customer. I found out the GPS (Ublox) was not "clean" so I had to reload 3DR settings on that GPS and it was fine.
Discarting GPS extreme changes like that would be nice... maybe you can trigger a mode where GPS is not needed it would help... but I can see some issues as well as there is no feedback sent back to the Pilot.... unless connected to MP on a ground station... Anyhow, avoiding a crash on bad GPS info would be nice, up to the devs guys to figure out the best actions to put once the GPS is "disabled until data returns more normal"....
Dany
Comment by Alejandro Martin Pirola on January 18, 2013 at 9:16am Glad you didn't lost your work in the crash!
By the way, nice spot, beautiful view.
Comment by Quadguy on January 18, 2013 at 10:31am I crashed mine because of loose battery. It got slipped out of its hold quad was performing Auto profile. It got dis-balance and crashed, nose dive negative pitch 30 degree
Comment by Crashpilot1000 on January 18, 2013 at 10:46am Beautiful flight (except for the end)
Did you try to switch back to stab. mode during the bank right? What Hardware/FW were you using?
Was the gimbal controlled by apm?
Cheers
Kraut Rob
Thanks for the comments and willingness to help me diagnose this : )
Sorry it took so long to get the log uploaded, I had to re-post the blog to get access to the "upload" function.
APM 2.0
AC 2.8.1
Gimbal controlled by APM, 20A v-reg on a separate battery powers input and output with no jp-1, this battery had plenty of juice left in it.
1208 MHz video Tx on it's own battery, with low-pass filter. not the first flight with this powered up, but the farthest from home position with it powered.
Once I noticed the misbehavior I centered the sticks and then switched in to stabilize but it was on the ground before the mode could change. The log shows no change in ch5 at the end.
The noise of the still spinning motors helped me find it quickly. There was no response to transmitter(Futaba T7C) inputs after the crash, I had to pull the motor power to stop them.
The rattling sound you hear during the death plunge was from some slop in the tilt pivot transmitting to the gp housing, it was not new to this flight.
I had 11 sats and 3dfix, My cell phone was in the car on airplane mode, the spot I was flying has no RF noise sources that I'm aware of.
Thanks again for any input!
I remain a loyal purple flight control fan boy 'till the end, can't wait to get 2.9 up in the air.
Forgot to add-
I'm using 3DR uBlox LEA-6 with a toroid on the cable.
Crash happens at 96% point on the log.
Comment by Greg Fletcher on January 18, 2013 at 4:40pm You had your gimbal gains dialed in nicely. Don't know about the crash. I just worked on the gimbal/mount code.
I do think it may be gps related. Switching sats causing an instant change in velocity can mess with the dcm.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
720 members
1355 members
207 members
Powered by
