I've been working hard to try and figure out this center of gravity deal. After enduring half a dozen crashes I finally got it right: I threw the airplane, the thrust was perfect, it was going just fine until... I pulled up and it went down. Thats right, my control surface orientation for my elevator was reversed. By the time I realized what had happened it was too late, and the MTP made its final landing, straight into the ground.
So if you've made changes to your airplane's control surface in anyway; your servo hookups, your control horn location, your transmitter settings, heck, every time you go to fly, just do a quick sanity check on your control surfaces, when you pull up, does your elevator go up too, etc...
I'm glad I made this mistake on a cheap airplane that could easily be rebuilt. I've got to experience these kinds of mistakes early so that as my models get more complex and expensive my simple errors will have been worked out my system.
I also learned that on a new model, put the CG a little nose heavy until you figure out where it should be, error on CG being t nose heavy. It appears that nose heavy is a lot more manageable than tail heavy, which is about as guaranteed to kill your airplane as it can get. I'm still amazing how much CG affects performance.
I also am falling out of love with Hot Glue. Its great stuff for a lot of reasons, I did entire episode on it a while back to prove that point. But, here in Arkansas, even when my model is in the trunk on my car, it gets hot enough (about 95 degrees Fahrenheit) to damage anything under some kind of pressure, where the hot glue will just fail.
I think I'll slowly move to some CA foam safe glue as I get a little better at not crashing everything I build in the first 5 seconds of my flight.
Trent, I like watching your videos. There are a few things to consider when building your next plane.
The plane you made is similar to the Ace Simple 400. With the diherdral it should be much easier to keep level...the Simple 400 would fly straight as an arrow but it doesn't auto-level in any way.
You'll notice how much shorter the nose section is vs your plane and that the wing chord is bigger giving it more lift. I also think you're way underpowered. What's your AUW? If you're in the 14oz range, then I would recommend a APC 9X6E prop and a 1300 to 1500kv motor. That should pull about 20-23A at WOT. You should be in the 60g range for motor weight. I would also strongly recommend a prop saver with o-ring instead of a collet directly on the motor shaft.
When testing CG it should be 1/3 back from the leading edge of the wing. I've had a few warplanes where the CG was right on the leading edge, but generally (and especially for your plane design) it should be 1/3 back.
I would also recommend only using CA glue with accelerator. Stop using hot glue. The hot glue is heavier melts too easily in your car and doesn't give you any better sticking power on the kind of foam you're using. Plus, you've got to have a car with an inverter to make a hot glue repair in the field. CA fits in your pocket and takes seconds to dry with a spray of accelerator.
Another thing I'm not sure about with your design. The "modular" aspect is not going to be helpful for this long range flight. As you can see from the crashes in this video, the nose and fuse modules are going to get destroyed together. Since you're making this out of 6-8mm foam, a hobby knife and some CA glue should make for a quick fix even without the modules. If this is going to be the platform for your disatnace flight you're going to need a LOT more payload room. You're going to need a Video TX, autopilot, GPS and camera plus probably a few sensors for current and airspeed. I'm thinking you're going to need to learn about hot wire foam cutting and plan to crash less (or bring a dozen fuselages with you on your drive).
Doing the math rather quickly, you're going to need to average 43MPH for 10 hours a day for 7 days in a row. That's 70 hours of flying!?!? Plus battery changes every 30 minutes let's say? This is going to be a VERY difficult task. You'll need a 2100 mah battery at least to get that 1/2 hour of flight (on a small plane) and a very thin airfoil to make the speed. It's going to have to be BIG to handle the winds you may encounter during rain storms and when flying across tha plains.
The more I think about this, the only way you're going to make this work is with about a 2 lb plane with a pretty good size wingspan (say 70"). I'm thinking carbon fiber for the wings and fiberglass for the fuse. It needs to be as aerodynamic as possible. The 2lb weight would give it enough ballast to handle some wind. One large drawback to moving the motor from the nose to the tail is you'll lose all slow speed control ability. There won't be any air forced over the control surfaces until the plane picks up speed....unlike when it's on the nose, as soon as you hit the throttle, you get wind over the controls. You're right that moving it to the back will protect the motor more on a crash, but without a prop saver, your prop is probably still toast.
So then there's the issue of the prop in the field of view of the camera. So you can either make a boom that sticks up over top of the prop to hold the camera or you can mount the camera under the plane pointed down a bit. Using the landing gear (maybe) to protect the camera.
Wow.... It's really going to be an engineering feat. Building a plane that's well suited for FPV, speed, distance, duration and is a UAV all in one.... I don't know if it can be done.
I've learned the hard way too, so now I always do a "CATT" check - Controls (direction and free movement of all surfaces), Antenna (check it's extended), Transmitter (Voltage, trims, switches, dual-rates) and Timer (start it, if you have one), then throw...:)
As for CG there's lots of CG calculators on the 'net, I start at 25% of the root chord of a conventional wing and move back from there after the maiden. 30% is sometimes too far back for a maiden. Here's a link to my favorite calculator: http://www.pdqdesign.co.za/CG_Calc_wing_best.xls
Full marks though for experimentation and perseverance! Good luck and happy landings!
Comment by Hamish on June 25, 2011 at 11:32am what are you trying to do ? find out how to make a plane by trial and error?
http://www.airfieldmodels.com/information_source/index.htm is pretty old but it has lots of info.
Everything at this mit course site is very interesting for basic aircraft design, especially this PDF
Comment by Trent at MyGeekShow on June 25, 2011 at 1:05pm My default glue is epoxy. It works on almost everything (except Multiplex airplanes I have heard) It is strong, and predictable. I reccomend getting it at your local hobby store, the one time I ordered it on line, one of the caps was loose, and even though it was sealed in a plastic bag, the inside of the bag was such a mess that I threw away the whole bag. Epoxy also requires small mixing cups and popsicle sticks, make sure to mix it well. I like the 15 to 30 minute variety, sometimes 5 minutes is not enough time to line things up. For some reason I have had bad luck with CA.
Comment by Michal on June 25, 2011 at 4:47pm Trent - I dont understand why you are publishing your efforts without digging theory first. It seems the only reason for this is to gain publicity. Without theory your attempts look indeed like trial and error. They will look like this till you will read more about the subject. Hamish gave you the links. Begin with pdf he mentioned.
The funny thing is that I posted you some advices on your YT channel and you deleted it. What was your point?
Comment by Trent at MyGeekShow on June 25, 2011 at 6:56pm Michal: I see your concern about my approach in publishing my efforts, just know that I do it that way for a few reasons;
First, it's a show, "my geek show" and to that effect is designed to show my progress, however weak or strong it is, in the end I hope it is worth watching for those interested in getting in the hobby, learning more about it, or laughing at my ignorance but impressed by my desire to not give up and figure it out.
Second, I hope that people learn from my successes/failures and won't make the same mistakes I do. I learn a lot this way; watching what others do, and I wish they too would not only show what works, but what didn't.
Lastly, I think showing the mistakes I make sheds light on the amount of work and testing we all do to get that perfect airplane in the air, it's not easy, but it is possible and the joy we get from the journey makes it worth it.
About deleting your note, I have a very strict belief about not removing comments on any of my videos/blogs/etc. as I genuinely value all comments, even those that are negatively criticizing my efforts. To date, I have only removed one as it only contained vulgarities, and I know it wasn't from you. If your comment was removed, I assure you it wasn't by me.
Thank you for watching and pressing me to be better. Someday I hope you will watch an episode and say: "Alight Trent, good job, that was worth my five minutes" : ) When that happens, let me know!
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.183 members
693 members
24 members
51 members
1298 members
Powered by
