This mod was also posted in another blog by me: http://www.rhinofablab.com/profiles/blogs/direct-pcb-printer
and I thought is more suitable to post it in DIY Drones.
Here I'll post step by step modification on my Epson S22/T22 to a PCB printer.
Below is a Epson S22/T22:
Taking bits apart:
Up to this point I test-printed a page to see if the printer works as before..
Pull the pins/plug off the board, then pull the power module out.
I put 2 washers under each point where the screws are, to raise the X-rail or the head rail, 1 washer = 1.04mm...
I got an error and my guess was that I raised the rail a bit too high, so I changed the washers to a thinner one, 1 washer = 0.75mm. Some people would raise the printer Head rest mechanism the same height as the washers, but I'm not doing that.
Test print:
Just few minutes ago I was trying out Epson printing options to get the best result of black ink on to the copper clad board, started by choosing Quality option---> photo the paper option--->Epson Photo--->print, then back to paper option--> Epson Glossy-->print and so on. The one that I prefer the most were Photo + plain paper, before printing I use a piece of sand paper fine grade and sand it over the copper clad so that the ink stick better, see the result
Adding Aluminium railings for PCB feed.
I used glue gun to hold the left rail to the printer housing, is faster.
Now build the right rail, this rail is not glued on to the housing.
Here is the dimension of the rails:
Updates:
PCB board feeding video:
@00:11 sec, I pull and push the board twice quickly to trigger the plastic lever for 'paper loaded', then the rollers pulls the board in. If you would push once sometime it will not detect properly and printer will assume that paper is not loaded.
Paper detection sensor upclose:
Comment by george on August 24, 2012 at 9:48am So cool!
Comment by Kabir on August 24, 2012 at 9:55am
Comment by Nick Arsov on August 24, 2012 at 10:52am Hi Fredy,
GREAT for prototypes! What ink do you use? What etching solution do you use?
Comment by Perecastor on August 25, 2012 at 1:40am It's not a laser printer....
On a laser printer you don't have a head printer ;)
It's just an ink printer ;)
Comment by Freddy on August 25, 2012 at 2:38am Thanks,
There are some other interesting link like this one: http://techref.massmind.org/techref/pcb/etch/directinkjetresist.htm", you can find out what ink to use in this link.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.249 members
183 members
693 members
24 members
51 members
Powered by
