Firmware and Windows Client are made from a modified version of the orginal one found here : arducam-osd
Update 30 January 2013, new version include :
To enable this feature and display selectable parameter screen (screen 1) :
After you'll we see a check screen (screen 2) where you have to :
Then you can select parameter (screen 3) to tune with CH6, those parameters are :
After tuning a paramter, go back to screen 3, and save new parameter value with yaw stick to the left.
Compiled firmware : 20130129_ArduCAM_OSD_.rssi.time.status.climb.current.tuning.mavlink...
Firmware sources : Arducam_osd_src.zip
Update 16 August 2012, new version include :
Compiled firmware : ArduCAM_OSD_.rssi.time.status.mavlink1.0.hex
Windows client sources : OSD_IDE.zip
Update 23 May 2012, new version include :
"Charset update" was removed hardcoded, so to upload a new charset, you'll have to use the orginal firmware to do it and after you can use this firmware.
This new version need a new charset (MinimOSD_20.mcm) and the new client
Firmware : ArduCAM_OSD.rssi.amp.status.hex
Client : OSD_Config_RSSI_Status_Amp.exe
Charset : MinimOSD_20.mcm
Thanks for your work on this mate. It will be a great help.
Veery nice, Airmamaf!
So, finally I'm getting a little better from the last surgery and I restarted to work on RSSI and MAVLink 1.0 support. I love to see what you've done. Officially, I need to follow APM progress on it in favor of people that don't compile the firmware by themselves. It means that we'll need native support from APM and MPlanner on providing RSSI reading and also on scaling RSSI percent, save the setup to the EEPROM, etc.
I still didn't find infos enough about RSSI on my radio. What RC are you using? I'm now installing a ChainLink Dare on a FlySky Radio.
Does it support MiminOSD 1.0 hardware?
Sandro, Just a note for scaling, nearly all radios will be different with respect to RSSI voltage values (from my experience) so maybe a tab in the set up page of mission planner requiring user to have radio on near plane for full signal sample, then switch Tx off for low signal sample. APM planner can then auto scale 0 - 100% giving the user an option to enter a margin value to their taste. ie A 10% margin value has the displayed RSSI reading 0% at 10% above Tx 'switched off' sample. Just thoughts anyway, glad your better too mate.
Also, looking at your Chainlink, to obtain an RSSI voltage should just be a case of looking at the voltage between the middle pin and grd pin of the connector next to the 'Com port' connector (labelled as "SPPM VRSSI GND" in the manual). You should just see a voltage range between about ~0.9v and ~3.3v?
Comment by airmamaf on May 23, 2012 at 3:12pm Hi Sandro, glad to see you're getting better, I get RSSI from my Turnigy 9x receiver as describe here RSSI from TGY 9x and I also made a simple rssi buffer.
About what just said George, it could be nice to have something in mission planner to calibrate RSSI, as we do for our radio, with for exemple max value (1m from receiver), min value (in microwave oven) and switch off value.
Got it... I'm worried on to know if it is linear or not. I mean, it would be nice if the RSSI voltage scale reflects a logarithmic based scale (dB) which would solve the problem of the non-linearity on the loss of power through the air.
Thanks by those infos on the 9X. And the microwave oven is a fantastic idea... =)
@George, about the ChainlLink... I hope so. I need to finish my install. If it's just a matter of read that ~0.9 to ~3.3v... I would just want to know if it's linear already.
@Eugene, MinimOSD hardware v1.0 is full firmware compatible with the old version. It just has a revised power circuitry with a switching regulator for improved cooling.
Not actually sure Sandro. If it helps, here is a video which displays raw RSSI voltage levels from a Dragonlink system from launch, out to about 5.7km. On the turn around it gets a bit erratic as electronics and battery get between Rx antenna an me. It may help you see how its scaled in the Rx.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.676 members
24 members
1283 members
4 members
8 members
Powered by
