Hello everyone,
I'm starting a new project branch for the ArduPilot, and I hope it will thrive. For an experiment run the DroidPlannerv0.1b.apk file on an Android Tablet (needs android v4) . Here it's a mere screenshot:
I know this it's not the first phone/tablet GCS to show up on this community (for example Bart copter-gcs, this closed-source copy, the Apple GCS by Zachary), but I'm thinking in a different approach. This is what I want to do:
Some great things are helping on this project:
Screenshots:
Before getting into how I think this should evolve let me show to you what I have already done. Bellow is a screenshot of the home screen where the mission planning is made. On the left there is a list of waypoints altitudes, on the center a map with the home position. On the top left a menu to change the screen and on the right some commands relative to this screen.
On the next picture there are show some of the actions on the menu, and more waypoints where added (with a different altitude). Using the "open file" action to open a real flight get's us back to the first picture in the post. (Files are loaded from a folder named waypoints on the sdcard, you can copy files generated with mission planner to this folder)
Edit: I added one more screen to the DroidPlanner App, is the Ground Control Point (GCP) screen. It's function is aid in the positioning of control points on the field for photogrammetry applications.
The operation is simple:
Here is a screenshot of the GCP screen with a KMZ file just loaded.
And this is after some GCP have been placed on the field and have been marked;
How it think it should evolve:
The part I'm procrastinating is the communication interface (mainly because Bart has made it already). I want to implement first a wifi-UDP communication system redirected by some main GCS, this way the development will be easier (the USB port will be free for the programmer) and a nice mobile GCS will be left behind. Next the USB-serial-Xbee communication, I have some working demos to receive data from the serial port but these need more study.
How to develop:
First get a clone from my branch "DroidPlanner_Stable" at this link. Next download the ADT Bundle for the google SDK and eclipse. Download and import the Google Play library into Eclipse as explained here. Now you should be able to import the DroidPlanner project/compile/ and run on a android device (needs Android v4).
Edit: About the USB connection to 3DR radios, some tablets have USB host capabilities and the drivers needed to communicate to a FTDI CDC IC.This means the device can supply power via USB and Acess USB devices, for me all it takes is an USB microB to USB type A cable (like the one in the picture).
To decrease the doubts about this here is a screenshot of my tablet connected to an APM1 board accessing the APM terminal. I used a terminal app called "Android USB Serial Monitor".
As I pointed out at the start there is this file: DroidPlannerv0.1b.apk, that can be run on a android v4 phone or tablet.
Edit: I only have one Chinese 7 inch Tablet, so I don't know how it will behave on other devices but it's worth a try. Some has run the App on a Nexus7. I had some doubts because of the API key need to access Google maps data was a debug one.
About android v2.x.x devices:
Edit: There seams to be a lot of questions about v2 android devices, these will not be supported. At least not on the initial releases. Because with android 2.X there would be some problems with the Google Maps API v2, and the communication drivers (since USB host mode is supported only on version>v3 devices). I know it would be great to support everyone but that is a lot of work. I think at least for the start just focus on android 3.1 or higher. this way we can use the latest version of the maps API and have USB support.
And an android v4 Tablet is very cheap now, and that's what I think should be targeted.
Any questions or suggestions post bellow. Any problems downloading or compiling the source contact me with a message on this post.
Thanks.
Arthur Benemann
Comment by Stefano Santucci on January 17, 2013 at 1:02am looks great .. will try soon on asus transformer prime
Comment by Chester on January 17, 2013 at 1:18am Very Nice. U thik a lot of us was waiting for this... Thank you very much.
I'll be perfect if we could use 3DR radio with Android Tab connected directly.
Comment by Andrew Parkinson on January 17, 2013 at 1:24am This looks very cool. Will I be able to use it to program and load missions just as I do with my laptop.
Will it power the APM as my laptop does when connected by cable?
Good work
Comment by Simon on January 17, 2013 at 1:43am Great!
Comment by Andy on January 17, 2013 at 2:10am Works on the Nexus 7.
Will help to develope this further. I started a month a go devloping the bart copter-gsc further so that it can handle more mavlink messages than before. Will look into your code, thx for sharing!
Comment by Simon on January 17, 2013 at 2:31am Which android tablets do have USB Host capabilities?
Cheers
-S
Comment by Vincent Mees on January 17, 2013 at 4:18am Fantastic! I hope this will be a full functional release in the end!
Thx
Comment by Samuel on January 17, 2013 at 4:23am Every china tablet with USB should work. I think the description has to say USB OTG to have USB support like mouse and keyboard. If this works the APM should get power too.
But does it work with USB? You need drivers and i dont know if you can bypass that somehow. If USB does not work you need to use BT but then you need a BT module that you can connect to the APM.
I'd like to help with development too, as i wanted to create a mission planner app for android as well. Would be really cool if USB works, then i just need a cable to set up my APM...
Comment by Samuel on January 17, 2013 at 5:03am Ok just had a look at this from adb shell. Looks like android recognizes the APM as serial device. I get output like this:
æ► äÓÜÇâ☺ Çı♫-ð±▲=W☺æ£W-@└► ╚∟♀►A♀¬2n #┴ ÉåÑ♦ ,↔@B☺^RY☺Уá▬ Ñ
↑ð│T$→F♠ÿ ê*♥ ♠Q@1ÉÇT☺¶ @Çû ╚Í♀z☺ж̷☺ñ◄ ╚é╩│ ó▬►└G☺h;ó→♥ ▬♀ ♠ ♀♂♣
[☺â↕ ↓ ╚ƒº?ÇÑ▼▲}@ÐW╦cÇ!← @▼ı«Çß▼►└E
╚9Ô↔♥ ↑§ ►ähré$[☺8♀ §ïwÇã☺³▼¤GÇÅ← ð↨ï}☺♣¦¶FÇ'=↨ð▓=l:J▲8 ▬
u+üé♥ └×íúÇÞ &×└â☻³♫Z[☺ └┼■G â╠}® Ã4►Ö♫Ëî┴♫╝ ¶Ô 0É® (èo♠É▲☻♠ô☻ÛEn_ Ó♀ ÂPÓ↕
¬♣ ↑┼á§◄ U♣ û ♣A$`└öÄm ♫◄ Éó☼z ‼ ØûE@♣ (─M♣♦0├♥↑XèÜP◄‗T☺ÇA ä─z ▼→ Ç♀Ç↔ └\ù→Ç♥ÌØ┤☺à♣
┬Ê ┴↓ ð▼►└$☻ü‗!1. 3├ Éåï♫ -ÍÇ┬
¶┤6 Ë↑@É♫º/@ú☻■♀O Ó♦ìÕÀ ♥☺³]û× =►Ó2↓L:J∟↑ ▬☻♣ ☺#I>ä└¥@X¶└Î☼y☺â◄ ░↨E^ÇÐòÊ→ ±↨âxÇï♥
HHE▒2. ♦ç☻ ♠ Xd 8ß╣☼P /Ç\♠@☺ É▲j╗@Ë▲óì☻‼▲¦½ Ô☺ └îüh ▲►└E♥Ïî┴¶< ¶☺♣ ☻↕IûÇß■ àFû└
ó@┴↑ ░♣lhAGU└`╬ÿ ♂#☺ ♀c`-►@º╦↔Ó(⌂└X♠@☼«¡Çß↑ Éî├{☻â _(◄‗³äùÿÇ└.►ÓÖ☻┘î┴¶< ▬ ♣ ♠│
ä♫♠¶├☺ └0☺»→☺¬§¦☺LM6 ╔ ■↕@Ç┼═▲ äû↨ß└ð♣☺Ô Ä @ð£∟` → <►pÖ♣Ëî┴▲╝ ▬à ►É®►(♀60☺°\╦õ
¨ ☺ùÅä☺P☺└↕ ■ò├¤ Å◄@ÉÇ ƒàZ☺ªE♥¦ ↨▼V☺☼ ☺è\↔ëÈ0═© ♂*♥ ♠! @ô)↔ à[♥ßó ■§Ø Ƕ♣Þð@°═_3 D
∟ò1 ♣ð-@Ò↕ └û♣=ÇÓûç│Ç#♣↓`"v5ÜB♦↑ ♥+☻ ♠ X
ÇÉM ☻ ◄ Þ÷ÂÁ@Ð̧Õ☺áò,Y ↕ ░¦Eƒüâ%→└◄V%→F♣ÿ -Ñ Ó▬/→☺*é@å☺Ç▬é/ǪMk%@┬→ @¶♦á☺
Looks like i get bytes, didnt have a look at MAVLINK yet, so i dont know if this is correct or not, but at least we can access the data the APM puts out, so it should work to use a USB connection.
Comment by Stephen Dade on January 17, 2013 at 5:23am Looks pretty awesome so far!
Like everyone else, I'd love the ability to directly connect a radio to the tablet/phone. Another idea is the ability to save flight logs - useful for a post-flight analysis on your PC.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.184 members
1290 members
51 members
11 members
182 members
Powered by
