We managed to get our hands into a Raspberry Pi 3 and decided to give APM a try with it using the PXFmini. Here’s a walkthrough over some of the tests that our team conducted:
Benchmarking
So, down to the benchmarks, we performed 3 types of tests using sysbench and the default Raspbian images (no APM running for now). SysBench is a modular, cross-platform and multi-threaded benchmark tool for evaluating OS parameters that are important for a system running a database under intensive load. The output of sysbench looks like this:
sysbench --test=cpu --cpu-max-prime=20000 run
sysbench 0.4.12:  multi-threaded system evaluation benchmark
Running the test with following options:
Number of threads: 1
Doing CPU performance benchmark
Threads started!
Done.
Maximum prime number checked in CPU test: 20000
Test execution summary:
   total time:                          477.3324s
   total number of events:              10000
   total time taken by event execution: 477.3236
   per-request statistics:
        min:                                 47.69ms
        avg:                                 47.73ms
        max:                                 85.54ms
        approx.  95 percentile:              47.72ms
Threads fairness:
   events (avg/stddev):           10000.0000/0.00
   execution time (avg/stddev):   477.3236/0.00
The output is graphed against the Raspberry Raspberry Pi 2 (note that smaller bars indicates better results):
sysbench --test=cpu --num-threads=1 run
sysbench --test=memory run --memory-total-size=2G
sysbench --test=memory run --memory-total-size=2G --num-threads=1 --memory-oper=read
The 64 bits CPU of the Pi 3 dramatically improves the results of this particular tests over the Pi 2. It’s 40% - 60% faster.
Mounting the autopilot:
We mounted the shield as follows which proved to be robust enough. Vibrations were kept at a reasonable level as will be shown later in the log analysis:
Flying with APM and log analysis
After a short flight we started some checks. The official documentation of APM will tell us:
“Check the scale on the left and ensure that your vibration levels for the AccX and AccY are between -3 and +3.  For AccZ the acceptable range is -15 to -5.“
Fine on this. We also felt that the drone was reacting really good so made a few plots that convinced us about the autopilot responses with the Raspberry Pi 3:
Conclusion
Raspberry Pi 3 is a great candidate to make APM Linux autopilots using the PXFmini!. Having Bluetooth and WiFi is indeed a great asset removing the need of using additional USB dongles unfortunately, WiFi is solely b/g/n and does not support the 5 GHz frequency band (which comes handy when flying with RC controllers that work in the 2.4 GHz band).
MR60
Comment by Hugues on March 2, 2016 at 8:00am
Nice. What's the hardware specs of RPi3 : CPU, RAM, etc ?
Comment by Víctor Mayoral on March 2, 2016 at 8:35am
Hi Hugues,
According to raspberrypi.org:
  • A 1.2GHz 64-bit quad-core ARM Cortex-A53 CPU (~10x the performance of Raspberry Pi 1)
  • Integrated 802.11n wireless LAN and Bluetooth 4.1
  • Complete compatibility with Raspberry Pi 1 and 2
It does indeed feel like a big improvement.
MR60
Comment by Hugues on March 2, 2016 at 8:39am
And in terms of connectivity and powering the board, is there any improvement vs Rpi2 ? (where a powered Hub was required which is a pain)
Comment by Víctor Mayoral on March 2, 2016 at 8:43am
None that i've been able to identify. For now, we are powering the Pi3 through the autopilot shield and using several dongles on it. Raspberry pi org mentions that it may be more power hungry though:
This time round, we’re recommending a 2.5A adapter if you want to connect power-hungry USB devices to the Raspberry Pi.
Comment by JB on March 2, 2016 at 8:45am
I like forward to the new A53 Pi compute model based PXF mini....when will you make it? The new compute module will be here in a few months. ;-)
Comment by Kabir on March 2, 2016 at 8:59am
Nice!
Does the single-sided mounting make plugging in connectors difficult? Does the board not flex or bend?
Comment by Víctor Mayoral on March 2, 2016 at 10:24am
JB,
I have no experience with the pi compute modules but sounds like an interesting idea. Will give it a though.
Kabir,
No it does not unless you apply a lot of force. The header and the spacers seem to do a pretty good job.
Comment by Jerry Giant on March 3, 2016 at 12:43am
Great report for the timing and quality.
I will begin tests on nVidia TX1, hope we can work together.
Comment by Jerry Giant on March 3, 2016 at 12:44am
Pi computing Module has been obsolete now, RS-online now dropped it.
Comment by Víctor Mayoral on March 3, 2016 at 3:01am
Hi Jerry,
The TX1 is indeed interesting. I'll PM you on this matter.
Comment
