I had a full day of autonomous flight testing in 20 knot winds, and it's clear that the default PID gains in ArduPilot were not high enough to handle any significant wind. So I upped them from 15 to 30 and the Superstar suddenly regained its tracking authority and was able to circle overhead well. I've modified the
standard code in the repository with these higher gains so others who saw "flyaway" behavior in wind should now have sufficient rudder authority to stay on track.
If you want to tweak your own PID gains, they're in the first tab of the code. The current gains are as follows:
//PID max and mins
#define heading_max 30
#define heading_min -30
Please note that with this higher rudder gain, it's important to ensure that your FMA Co-Pilot is doing its job with wing-leveling. Once you're in the air, set it to the highest gain it can take without oscillating (if it's a clear day and you've calibrated it right, that should be the maximum rotation of your gain knob on your transmitter).
Another issue with using ArduPilot 1.0 in high wind is that altitude hold is pretty sloppy and it has trouble making progress upwind. That's because ArduPilot 1.0 just uses the throttle for altitude control. When the plane is going into the wind, it tends to rise. ArduPilot will then cut the throttle, but in a good headwind, the plane may not descend. Instead, it will just hover or even move backwards a bit.
That's why we're shifting to elevator+throttle altitude control in the ArduPilot 2.0 software. With that the plane will point its nose down a bit and keep the throttle going to make headway against the wind. It's a much better way to control altitude. Jordi's testing it this weekend and may have the code ready to release this week.
