Inexpensive Landing Gear Solution
3689509775?profile=original
Weighing in at only 30 grams each, these legs will help lessen the impact of most hard landings and generally decrease vibration damage to instruments on the vehicle. This also increases ground clearance by 2 1/2 inches. Spring-loaded toilet paper holders are fairly ubiquitous in America, so Brits and most Europeans are SOL, as their TP dispensers are only metal poles with a tiny balls at the end. Asia might be the same. I'm not sure how common Wiffle balls are overseas, let alone golf ball-sized ones. But as necessity is the mother of invention, I'm sure they will prevail. Also, ping pong balls are the right size, but shatter easily.
The fat end of the roller is right up against the arm, so I put two layers of shock absorbing foam in between. There's a small protrusion at either end of the roller (to keep it in the holder), so slathered it and one of the holes in the Wiffle with rubber cement and merged them. It's best to use a flexible adhesive as crazy glue or any cyanoacrylate will snap the moment angular pressure (i.e. landing) is applied. A binary adhesive will surely bond them, but may turn the Wiffle ball into a Wiffle puddle.
  • Really Great Idea,
    Definitely outside the box or at least the bathroom.
  • By the way, it's about $5 US for 6 balls (@ Amazon) and six rollers (at the 99¢ Store, don't bother with Amazon).
  • Great idea for shock-absorbing landing gear! This is definitely a keeper as I've never liked hard landing gear.
  • What an awesome idea!  If you paint it to match, it will look like it was made for the vehicle.  Nice pictures and graphic panel too.  I will not ask where you were at the time that you had this brilliant flash of creativity, but nice work.  Thanks.
