Juno Drone
Juno Drone frame designed by DWDrones.
 Juno1_ed_large.PNG?331
3689627953?profile=original
Hi DIYDRONES! I saw the Juno battery on here many months ago and decided to buy it. It's stated as having a 12 volts, 300 peak amps and 6000mAh capacity. I had hopes to use it for some of my drone projects but the shape didn't quite fit my current drone frames. I decided to make a drone around the battery instead! It's being printed right now. I will followup with post production pics!
Daniel Lukonis
DWDrones.com
Primary Design Goals:
Created to work with a JUNOJUMPR (Black) by JunoPower.
Designed to be 3D printer friendly.
Intended Part List:
JUNO JUMPR (Black)
5" Blades
2150KV HK Baby Beast motors
12 Amp HK Afro ESCs
HKPilot Mega Mini flight controller with GPS
FrSKY D4R-II Reciever
3DR radio
The JUNOJUMPER battery slides in through the back and connects with 2mm plugs mounted in the body.
Juno3_ed_large.PNG?333
All electronics can fit comfortably inside the body. ESCs (green), Flight Controller (purple), GPS (orange).
 Juno6_ed_45045ce5-0ec1-4daf-bc61-2ef9fd92f916_large.PNG?337
Top View
 Juno2_ed_large.PNG?332
Front View
Juno4_ed_large.PNG?334
Expanded Parts View
The 3D Printing plans have printer helpers that can be snipped off post production.
Juno7_grande.PNG?338
  • Great work... function over form, always!
    Re the battery itself, I can certainly see how it would be nice to be able to connect/disconnect a battery more easily.
    For the design of the copter, I'm not an expert but I think it's good to keep the center of gravity on the same plane as the motors/propellers.  So it might be slightly low in your design.
  • Indeed Mike! I'm just uploading them now. They will appear here shortly:
    http://dwdrones.com/pages/juno-drone
    Once I get the 3D printing done, i'll post up some instructions for assembly with pics.
