Came across this great product for antenna building for UAV's. Adhesive backed copper foil 5 mm wide. Great for creating your own dipoles, vee's or helix, easily soldered. Attach it to fiberglass or plexiglass or directly to the foam (prepped with acrylic spray to help adhesion or just taped over with package tape).  Create dipoles or vee's directly on you wings (not over your carbon fiber spars though).
Keep experimenting!
This is available at Sparkfun. https://www.sparkfun.com/products/10561    $2.95 for 50 feet
Comment by Travis on October 7, 2012 at 11:25am
If you're making any circuits out of copper tape, do yourself a HUGE favor: make sure to get conductive adhesive copper tape (I can't tell if the SparkFun product has conductive adhesive or not).  I spent 4 hours debugging a touch sensor once just to learn that this was the problem.  Also... I frequently build antennas out of copper tape.  It's great, since an x-acto knife can be used to tune the antenna.  Just be sure to solder all connections to ensure good RF conductivity.  RF is different from low-frequency operation -- something that has 0-ohms at DC can be an open circuit (or extremely lossy!) at 900 - 2000 MHz.
Comment by james sowell on October 7, 2012 at 11:35am
are you going to rig 1 up on the x8?
Comment by Hein du Plessis on October 7, 2012 at 12:27pm
If only my wings were vertical :)
Comment by Geoffrey Preston on October 7, 2012 at 12:42pm
@ James Sowell
Long time no talk.  It seems that I'll be using a lot of different bands with the X-8. 430 mhz for the radio control, 900 mhz for telemetry, 5.8 ghz for video and 144 mhz for a locator beacon if I crash it. The idea was to keep the antennas in the cockpit but it looks like I might need to add Vee antennas on the wings using the copper tape.  Hope you saw the blog post about the Wheel Antenna that will be used for telemetry. You been flying? I still havent started the X-8  yet (got all the parts though) but have been building a CTH Deep Reaper so I could get in some aileron practice and to try out some of the antenna ideas.Would  rather crash that than the X8
Comment by james sowell on October 7, 2012 at 1:10pm
yes on wheel ant. all over my head,I will go to the x8 page on the rest so its all in 1 place
Comment by Ryan Alexander Bahr on October 8, 2012 at 12:03pm
Can I ask why you suggest the conductive adhesive?
Comment by Geoffrey Preston on October 8, 2012 at 12:18pm
@ Ryan
  I dont suggest it for antennas. That was a comment by another that was intended to be cautionary if the copper tape was to be used for circuit boards. For antenna puposes it simply isnt necessary.
Comment by Ryan Alexander Bahr on October 8, 2012 at 12:34pm
Sorry I should have addressed that at @Travis.
Even for circuit boards, I believe I would rather have it insulated as much as possible and create my own connections.
But I believe for an Antenna, if it wasn't insulated/non-conductive adhesive, moisture could detune the antenna compared to one that wasn't exposed. Is this a correct assumption? I am only getting into antennas this semester.
Comment by Geoffrey Preston on October 11, 2012 at 7:48am
@ Ryan
  Without knowing your installation its difficult to say if the antenna would de-tune. If its mounted to the surface of a wing, exposed to weather, yes i think moisture would be an issue. I'm preparing to use this copper tape to put a 430 mhz and  900 mhz horizontally polarized Vee antennas on my  CTH Deep Reaper. I plan to cover the antennas with clear package tape to keep them from damage and mositure. I'll post some photos when I get them installed.
Comment
