Your Blimpduino kit comes with most of what you need to compete the blimp, and all the hard-to-find and unique parts. Here's what else you'll need:
- A soldering iron and solder
- A FTDI cable (either ours, or the Sparkfun board and a USB cable if you don't have one already) to program the board.
- Helium (Available in the balloon kits available for $18 at Target, or a larger tank from Amazon)
- A 7.4v LiPo battery (any other one of that approximate size and capacity will do, as long as it's under about 35-40 grams)
- A balancing charger (This one, with this power supply, will do the trick and is inexpensvie)
- If you want to use RC mode, you'll need an RC system with at least three channels. Any will work, starting with simple systems such as this one. You''ll also need two female-to-female RC cables.
- A 9v battery for the ground beacon
- Double-stick tape to attach the board to the gondola
- Velcro tape to attach the gondola to the envelope
- Superglue
Join this Ning Network
