Ok - so the critical sub systems for keeping balance, headings etc, are probably best served by a RISC type processor like the ARM and ATMega processors. But on top of that, you could put something that allows an easy access to image processing, communication, logging etc.. In the USAV project I use an Android phone (ARM 600 mHz) to handle the more high level stuff - such as navigation, telemetry, Twitter integration etc... Even though this system is remarkable fast when doing just that (a distance + heading calculation takes roughly 2 milliseconds), this system will be affected once starting to do image processing etc...
I just stumbled across this little thing, that surely would be more powerful and extendable.It has an 1.6 GHz atom processor and uses only roughly 4 watts. You can run any operating system on it and connect usb devices.
The size is only 3.50 x 2.36 x 0.63 inches (89 x 60 x 16mm) which would make it fit in many UAV's.
http://www.linuxfordevices.com/c/a/News/Toradex-Xiilun-PC-and-Topaz...
Comment by Jesse on February 15, 2013 at 3:19am The day is certainly coming that we'll no longer use microcontrollers, but rather, microcomputers. Pretty exciting!
Comment by Angelo DP on February 15, 2013 at 3:26am 1.6 mHz is 1.6 milliHertz. :-) 1.6GHz is probably correct
Comment by Jesper Andersen on February 15, 2013 at 4:39am @Angelo: Ooops! Embarrassing! :-)
Comment by CrashingDutchman on February 15, 2013 at 5:37am
Comment by Jesper Andersen on February 15, 2013 at 5:55am Very interesting - they mention credit card sized once fully developed.
The board in the video is definitely too large, so lets hope! :)
Comment by J on February 15, 2013 at 12:22pm ++ on the Adapteva. Why be an inchworm when you can step across mountaintops? No offense @Jesper--your bot is way cool. But for this guy I would ditch the old set top box rig & use Go on Plan9.
In the meantime, much of the Intel/Willows Garage vision libs are ported to GPUs--5-100x speed up.
Comment by Jack Crossfire on February 15, 2013 at 6:23pm Their fastest product, the Apalis T30, is equivalent to 6 raspberry pi's on a single slightly smaller board, & a lot less money per clockcycle.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1288 members
24 members
78 members
51 members
682 members
Powered by
