Propeller design for 3D printing
3689477575?profile=originalLots of people have suggested 3D printing propellers, but Landru is the first I've seen to do it. Looks pretty good! (I'm not sure I'd trust my old Makerbot with this--he's got a better printer.) He writes:
This is a redesign for an 8040 printable propeller with a 5.5mm (13/64") bore.
This prop was designed to keep the minimum cross section above .8mm allowing it to be more easily printed, though at a small efficiency loss.
The propeller will require support on one edge, which makes it very easy to remove.
I can redesign this for some different center hole diameters if requested, just give me some time as I am pretty busy.
Here is a short video with the prop on a motor:youtube.com/watch?v=v6yClT12Ges&feature=plcp
I will also be uploading a 5030 prop once it is flight tested.
I printed mine on a Fablicator using Kisslicer.
  • It is some time that I use my makerbot thing o matic for some parts of my quadcopter. First some minor parts, then i've discovered that ABS can be used for almost everything if used properly. Now i'm testing light motor Mount (quad auw weight is 1.4kg!) long life to 3d print!! :)
  • for that kind of shape a cnc router seems to be a better option
  • John, I agree.  It's a really interesting concept, and I'd love to be able to make my own props that are custom designed for a multi-rotor.  Similar to those nice CF ones you got, but in 12".  But I also really question how strong they'll be.
    It's a great indication on how the future will be. Just browser and click on a object, and some time later it comes out of the printer.
    But frankly, I am having a hard time trusting the current 3D printers for something as sensitive as a propellers. You would not believe the amount of strain a propeller has to endure during flights.
  • That's cool, but I guess it is still cheaper to order them lol
