Finally the last missing board from the PX4 series has been released, the PX4FLOW smart camera module. It can replace GPS in indoor and outdoor applications and provides a metric position close to the ground with only very little drift. It is essentially a microcontroller hooked up to an automotive-grade machine vision sensor that can be freely programmed.
Given the wide distribution of the AR.Drone one might ask what the purpose is, and the answer is simple and well illustrated by the video: You can use this board with PX4FMU and the PX4 native autopilot stack, but you can also interface it with any other system, including Linux onboard computers running ROS. It works indoors and outdoors and brings the same stability the AR.Drone shows in flight to any aerial robot.
It has a native resolution of 752×480 pixels and calculates optical flow on a 4x binned and cropped area at 250 Hz (bright, outdoors), giving it a very high light sensitivy. Unlike many mouse sensors, it also works indoors and in low outdoor light conditions without the need for an illumination LED at 120 Hz (dark, indoors).
As the aerial image with overlaid trajectory shows, the position estimate is very accurate. This is without GPS, captured in flight at 1.6 m altitude and in one pass.
The work on this module has been accepted at the International Conference on Robotics and Automation (ICRA 2013) in Karlsruhe, Germany: Dominik Honegger, Lorenz Meier, Petri Tanskanen and Marc Pollefeys. An Open Source and Open Hardware Embedded Metric Optical Flow CMOS Camera for Indoor and Outdoor Applications, ICRA2013
The module has been developed by Samuel Zihlmann, Laurens Mackay, Dominik Honegger, Petri Transkanen and Lorenz Meier.
Frequently Asked Questions
More information needed?
Comment by Neil Ohnemus on February 5, 2013 at 4:29pm "You can use this board with PX4FMU and the PX4 native autopilot stack.."
Will there be/is there a plan to support the optical flow sensor with arducopter PX4 release?
(I'm assuming here (dangerously) that PX4 Native stack is not arducopter)
Great to see this available.
Are Arducopter drivers going to be working with it when the PX4 version of Arducopter is released?
By the way what ever happened to the APM optical flow hardware?
Hasn't been available from 3DR for months now.
Looks like the PX4 is going to be the way forward.
Comment by Jack Crossfire on February 5, 2013 at 5:49pm Ever since helicommand 1st commercialized optical flow, the question has been if it can only achieve that accuracy 1.6m off the ground, what's the point of having it fly?
Comment by Ryan Alexander Bahr on February 5, 2013 at 5:50pm I've been waiting for the optical flow sensor for quite some time. I know they said here they don't plan to introduce a low cost version but I hope that the Arducopter version isn't in that category.
Comment by Adam Conway on February 5, 2013 at 7:33pm Clearly, I have not been paying attention because previous posters are treating this as ho-hum, but this is so cool (this is the equivalent of me freaking out, like, boy-band freaking out; for those that don't know me I am a mild mannered sort of guy).
Comment by Jason on February 5, 2013 at 7:59pm yeesh... it has the maxb. sonar attached.... is this removable?
Comment by Greg Fletcher on February 5, 2013 at 10:14pm With several of these surouning the craft, maybe eight of them like a spider eye system. Sense and Avoid, the big kahuna, the holey cup.
Comment by Don Park on February 5, 2013 at 10:18pm Can someone say more about how this sensor is being used? "provides a metric position close to the ground" is not very clear. My best guess is it replaces a sonar sensor to determine position above the ground.
Comment by Adam Conway on February 5, 2013 at 10:48pm based on what I have read, It measures ground movement below the quad copter, which means that if you quad is moving slow enough or the camera is going fast enough you can get accurate, relative 3 axis navigation (x, y, yaw) - the sonar gives you a 4th axis (z). If you know your start position and can measure relative position accurately then you know where you are. I suppose it is possible to get roll and pitch within reason but I suspect that the system has been simplified to just give those 4 axes... I guess we see when the source is available.
Comment by Adam Conway on February 5, 2013 at 10:51pm I was just thinking of this and I guess it would be completely possible to get roll from these sensors by watching the distortion of the image however and with a lot less noise than a IMU. the challenge is that it would be difficult to sense the difference between sloped earth and roll/pitch.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.15 members
721 members
203 members
1356 members
5 members
Powered by
