Review: Multiplex EasyGlider Pro for UAV use
We all love the Multiplex EasyStar, but for autopilots that separate stabilization and navigation, its lack of ailerons is a limitation. (Stabalization--FMA Co-Pilot in our case--uses ailerons and elevator; navigation uses rudder and throttle). The next plane up in the Multiplex family is the EasyGlider, recently upgraded for brushless power with the EasyGlider Pro. It's bigger (71" wingspan vs the EasyStar's 54"), has ailerons and can lift more weight. But it's also a lot more expensive ($256 with power package, as opposed to just $66 for the EasyStar), and the front-mounted motor takes up a lot of interior room. How suitable is it for a UAV? I got one and tested it out last weekend. Here's my report:
As with all Multiplex kits, the build quality is excellent and the Elastopor foam goes together nicely with CA glue. If you get the optional power kit, all you need is four servos (2x HS55 and 2x HS81), a Deans connector, and a LiPo battery, along with your RC kit. You can put it together in one evening.
I of course added a FMA Co-Pilot, and mounted the sensor above the wing. The plane is slightly nose-heavy in this configuration, but nothing a bolt or two in the tail can't cure. But when you put in all the equipment, you'll spot the first big disadvantage of the EasyGlider Pro: it's got less room inside than the smaller EasyStar!
That's not just because the motor and the ESC are in the cockpit. It's also because the servo and pushrods are, too. In the EasyStar, they're all on the outside, leaving the cockpit entirely open for radio and camera equipment, but in the EasyGlider you have to share a narrower (albeit longer) space with everything else.
You can see the two side-by-side in this picture:
The EasyStar is closest to us (it's the beat-up one!) and the EasyGlider is behind it. Even though I've added a camera-trigger servo on the EasyStar it still has more unused space than the EasyGlider. The only way to add more space to the EasyGlider would be to create a second "floor" layer above the servos and put autopilot equipment on that, under the foam canopy. Otherwise, anything you stuff in there risks tangling up with the servos, pushrods and other wires.
Obviously, the other problem with the EasyGlider is that it's hard to put a forward-looking camera in it, since the prop is in the way, something which isn't a problem for the EasyStar with its pusher prop. There are people who have modded the Easy Glider to put the prop in a pusher configuration with a pylon, but that's too much work for me ;-)
As for flight, the EasyGlider flies really well and the ailerons give more precise control than the EasyStar's rudder. But it's also a bit harder to fly for beginners, and if you crash nose-in, you're going to damage the prop and maybe the motor, which isn't a problem with the indestructable EasyStar. I found that the FMA Co-pilot had a hard time maintaining level flight at high gain settings, but that may be due to calibration problems. I'll have to test a bit more to see what the problem is.
Bottom line: I prefer the EasyStar, but since I need the ailerons I'm going to continue working with the EasyGlider and create an autopilot layer for the cockpit as mentioned above. What I love about these foam powered gliders is that you can fly them anywhere and they can land on any surface without damage. So as an autopilot test platform, they're great for quick trials and experiments. But I wouldn't recommend the EasyGlider as the optimal UAV platform for serious use. For that, you'll want the usual high-wing trainer, even if that means having to take off and land from a proper runway.
Comment by Tyler Nighswander on December 4, 2008 at 9:27pm
I've never done it, but there seems to be a lot of stuff online about adding ailerons to the EasyStar.
It might be nice to do since you'd get more control, and all the room, but I don't really know if it might change around other things in flight. Might be worth trying if you haven't, since you know what you're doing, whereas I would surely break things : )
Comment by Sgt Ric on December 4, 2008 at 9:46pm
See rcgroups for threads exactly about this issue.
Some people find that it looses it's inherint stability after adding them, but yes an Easystar would need an aileron mod before adding an autopilot.
Comment by Michal on December 5, 2008 at 7:04am
The best and quickest thig is to add Easy Gider wings to Easy Star (+little sanding). This way you can have ES + ailerons + FMA + autopilot.
Comment by Chris Anderson on December 5, 2008 at 8:42am
@Michal: Very interesting idea! Any idea how it flies with such oversized wings?
Comment by Pat on December 5, 2008 at 9:18am
Great review, Chris! Especially after your comments to me last week about the EasyGlider for use with the autopilot. I like Michal's idea of using the Easy Glider wings with an Easy Star for all the technical reasons that make sense, and it also saves a bunch of money (I think an EasyGlider standard without equipment is about $80-90).
Another option is to investigate the use of rudder for both stabilization and navigation. This is not an overly compicated problem, but it involves a different control architecture that I am quite familiar with. When I get my ArduPilot, I will begin experimenting with this.
Comment by paul hubner on December 5, 2008 at 9:18am
I moved to the Easyglider a while back, and converted the unpowered version to a pusher. Though I know I regularly overload the plane and that makes it sluggish, I do like having ailerons and added lift. My other mod was to the cockpit. After a particularly ineffective landing, just just replaced the front with a home built elapor foam box. Plenty of space now, and continuing to uphold its FrankenPlane II name :-)
Comment by Michal on December 5, 2008 at 10:15am
My Focus from Pelican (EZ clone) flyes very good, with slightly higher elevator response due to shorter fuse than Easy Glider. It is very stable and genteel ;). It doesnt want to land till the big wings :)
Here is the discussion on similar subject:
http://www.rcgroups.com/forums/showthread.php?t=810365
Comment by Michal on December 5, 2008 at 10:22am
It is a must to change rudder in EZ. I have the EZ fuse now and apart of adding some protective armor to the front I will redesign vertical stab adding some area to rudder. When using rudder along CPD4 it could make a circle around 30-40 meter radius with vertical stab fom Easy Glider in a calm day.
Comment by Chris Anderson on December 5, 2008 at 10:32am
I've got a spare EasyStar fuse and I've ordered a spare pair of EasyGlider wings and rod, so I'll see if I can create a combo that works without destroying the two planes I've got. I agree that you have to at least double the size of the EZ rudder. If it works well, it can bring the cost of the combo to about $150 (EasyStar, EasyGlider wings+rod, upgraded brushless motor, ESC, prop), which is $100 less than an EasyGlider and better for UAV use.
Comment by Michal on December 5, 2008 at 10:42am
I have spare wings from Graupner Electro Junior which I believe would add more controll and speed to EZ than wings from EG. I will report here when I will have more information about this configuration.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
