Safety First Before Flying Your Drone Outside
Fly Your Drone Safely
Before flying your drone outside, you must familiarize yourself with your country’s current regulations (find these via Google).
3689621321?profile=original
The Boring but Essential Stuff
3689621408?profile=original
Typical rules include:
• Maximum altitude of 120 meters (approx. 400 feet).
• Maximum distance from the operator of 500 meters (approx. 1600 feet).
• Drones should be flown at all times in the sight of the operator.
• Drones must not be flown within 8 kilometers (5 miles) of an airport.
• Drones must not be flown within 50 meters (approx. 160 feet) of structures, vehicles or people not under the control of the aircraft operator.
These rules are actually very sensible. You DO NOT want to lose control of your drone and be the cause of an accident.
Please always keep safety at the front of your mind.
Getting Off The Ground Safely
3689621374?profile=original
Just as with commercial airplanes, accidents are most likely to occur with drones on takeoff and landing.
Successful takeoff?
Firstly, make sure your drone is on a level flat surface. This is very important.
Next, ensure that your drone and transmitter batteries are fully charged. Additionally, check that the blades are able to spin freely.
Once you are satisfied that the equipment is operational, you can sync the drone and transmitter. Be sure to keep a good distance away from the drone before starting the motors.
You’re ready to fly!
If you have practiced sufficiently on a flight simulator (loads of applications now available on Apple and Android App stores), then you should be able to get your drone up and flying without too much difficulty. The key thing is to start off slowly (no sudden movements) and to keep your drone at a low altitude until you are confident with controlling it.
Realistically, you are going to need many hours of flying your drone before you can reach a competent standard. It is quite possible you will crash your drone. This is why it makes sense to be outside in a field or park - well away from people and buildings.
With practice, you will also be able to land your drone softly and precisely.
Top Tips for Flying Safely at All Times
3689621419?profile=original
For example, we own a number of drones from large to small, including good starter Drones Cheerson CX-20 /Quanum Nova and a Hubsan X4. The Hubsan X4 is a great low cost very robust entry drone, and 9 times out of 10 in a crash it's just a case of adding replacement propeller blades and popping the frame back into place.
To save you money, avoid accidents and heartache, we strongly suggest the following:
READ YOUR DRONE INSTRUCTIONS - and if lost, or if you have difficulty understanding them, find the information on the Internet (for example: visit the manufacturer’s website, look for advice in forums, view tutorials on YouTube).
• If you have self-assembled any part of your drone, triple-check the setup configuration.
• Although drone/quadcopter propeller blades look the same, they are different and must be installed in the correct configuration to create the required lift and control. If installed incorrectly (round the wrong way) you drone will fly out of control and smash into the ground.
• Don’t try to show off with your drone.
• Always have spare blades available.
• Find an outdoor area with more space than you think you will need.
• To avoid damaging your blades (or yourself), fit blades protection guards.
• If automated stability controls such as GPS fail, be ready to take manual control and land.
• Time your flights and be alert to the battery alarm or light signal. If alerted, return your drone immediately to your position to avoid any possibility of a crash.
• Be wary of flying your drone when the wind speed is more than 10 mph. Sudden gusts can cause you to lose control of your drone.
NEVER leave the batteries charging unattended. Most drones and radio-controlled aircraft use Lithium Polymer batteries (additional LiPo info Link)  because they offer excellent high-energy storage, and are lighter than equivalent batteries. However, LiPo batteries if not charged correctly, can become faulty, catch fire, and even explode.
Drones are not toys, and should only be operated in most cases by responsible adults. If you really want a child (recommended 14 years old and up) to fly your drone, at least make sure they are fully trained, and you supervise their flying at all times.
If you are ever in any doubt - please put safety first.
Enjoy your flying!
3689621383?profile=original
Helpful links
Academy of Model Aeronautics
http://www.modelaircraft.org/
http://suas.modelaircraft.org/ama/images/sUAS_Safety_Program_web.pdf
Association for Unmanned Vehicle Systems International
http://www.auvsi.org/
http://flyresponsibly.auvsi.org/home
Federal Aviation Administration
http://www.faa.gov/uas/
Learn about the Drones, Quadcopters and Multicopters
http://dronesarefun.com/
Selection of Starter Drones
IRIS+ from 3D Robotics Link
Cheerson CX20/Quanum Nova (similar to the DJI Phantom)
DJI Phantom
Hubsan Q4 nano http://diydrones.com/profiles/blogs/bumble-bee-size-quad
Hubsan X4 H107C with HD 2MP CameraA
Blade 180 QX HD
Posted by FlightBots.com - The Home of Friendly Drones
  • Admin
    @FlightBots,
    Nice summation and excellent information for both the beginner and experienced user.
    TCIII Admin
