Just been testing this "new" copter.
Good
Stable flying
Easy to build
PnP no need for installing code
Can be finetuned via software, but has 3 knobs to adjust gain in field.
Bad
ESC: Got problem starting the BL motor, but when motor are running it's pretty powerfull. (Need slow startup)
Navigation mode: (hold position and RTH) need more testing. Not working very well.
Some drift: (maybe better prop or balancing motor/prop could help)
All in all: Nice little Y copter. The FY91Q can easily be intergrated in much bigger frame with bigger motor /ESC or be used in other configuration (like X frame).
Need for work with the RTH or Hold position function, too early for me to say it's rock solid.
Pilot: John Jensen, DK
yes apparently
i hope you will continous to give news on this forum
i would like to buy one but it s hard to find a reviews about this module..
i know it s news on the market so they will have lots of improve before to be perfect
Just updated the software! so now it's time to test it.
Should have a better hold altitude function.
Here's the link to the FY91Q controller. It costs $400.
FY91Q Navigation edition
The battery is 3S 2200 mAh Lipo Turnegy 20C and Rino / about 7-10min flying.
Can take bigger battery.
Nice smooth run.
What about the battery size and the max air time yet?
Love the copter frame stucture.
Look sturdy with less air resistance between the props.
