Sky Drone FPV 2 - Long Range 1080p FPV Video + Command & Control - now available for USD 299.-
Optimizing our supply chain allowed us to make our Sky Drone FPV 2 system available at a dramatically reduced price, starting from USD 299.- for the Europe/Asia version and 329.- for the US/Verizon version. The previous price was 699.-.
Sky Drone FPV 2 is a HD camera system for drones that transmits over the LTE network providing an unlimited range and low latency video+data link.
Digital High Definition Video
The Sky Drone FPV 2 system uses a high resolution camera with a wide dynamic range. It provides you with an amazing live video feed of up to 1080p at 30fps.
Telemetry and Command & Control Link
Besides the video link, Sky Drone FPV 2 provides a bidirectional data link between your drone and your Ground Control Station. This can be used to visualized telemetry data and/or control the drone. We support the MAVLink protocol as well as any generic protocol that interfaces via RS232/UART.
Unlimited Range
By using existing cellular networks, the Sky Drone FPV system provides you with virtually unlimited range. The only requirement is cell tower coverage. The system is optimized for the 4G/LTE network to provide best video quality and lowest latency. It does however fall back to 3G or even 2.5G networks by automatically adjusting video parameters without interrupting the stream.
Low latency
By using our own highly optimized video processing pipeline, the system is designed for lowest latency video from scratch. The typical end-to-end latency is less than 150ms.
Groundstation Software
The Groundstation to receive Video from the Sky Drone FPV 2 unit runs on Windows and Linux with version for MacOS, Android and iOS in the pipeline to be released in Q2 2017.
Interchangeable Lenses
The Sky Drone FPV 2 system is using high quality lenses that are interchangeable. Instead of locking you to a specific lens, you have the freedom to change the lens for specific use cases (wide angle lens for best overview or narrow FOV lenses for artistic flights with less distortion).
Security
The video stream and meta data are fully end-to-end encrypted making it impossible for third parties to eavesdrop the transmission or interfere with it. Rather than reinventing the wheel, we rely on open and proven standards including Datagram Transport Layer Security (DTLS) and Secure Real-Time Protocol (SRTP) using AES128.
For more information see https://www.skydrone.aero/products/sky-drone-fpv
Comment by Kevin Klemens on April 21, 2017 at 1:08pm
Is there a manual I may be able to read about the set-up?
Comment by Rob_Lefebvre on April 21, 2017 at 3:22pm
Darn, I was interested, until LTE.  Would be unuseable over about 97% of Canada's land mass.
If you ever get a full direct digital link, I'm interested.
Comment by Jonathan on April 21, 2017 at 3:41pm
Has the XU4 inside?  Might be able to run some of your flight control software on this.
Comment by Auturgy on April 22, 2017 at 12:11pm
What's the benefit of this product vs a companion computer with APSync, dongle and camera?
Comment by SkyDrone.aero on April 22, 2017 at 10:28pm
@Kevin: send us an email (info@skydrone.aero) and I will provide you more details and the manual
@Rob: yes, there are scenarios whrere our system is not usable at the moment. But I am quite sure ubiquitous internet access - even in remote regions of Canada - will eventually come :)
@Jonathan: Sky Drone FPV is based on an embedded system streamlined and optimized for it's core functions. So currently it is not possible or intended to run any other software on it.
@Auturgy: LTE direct peer to peer communication; low latency optimized; full end to end encryption; and much more
Comment by Auturgy on April 22, 2017 at 10:46pm
Ok, sales pitch statements. I'm still not convinced that this is any better than what is easy to do with cheap readily available hardware running free software. I'd be interested to hear your average and maximum latency(end to end) - you can tweak and tunnel as much as you like but ultimately the network you're on will have constraints you can't control. If it came coupled with an awesomely cheap data plan, I might be interested
100KM
Comment by Hein du Plessis on April 23, 2017 at 1:20am
This is terrific, up to now, I've been using the "easy to do with cheap readily available hardware running free software" option @Auturgy mentioned, but I find it anything but easy and I don't think much cheaper than the 299 of this system.
Your response to Rob around LTE - your write-up mention falling back on 3G if not available, so the system is indeed usable almost anywhere with cell data coverage?
Comment by SkyDrone.aero on April 23, 2017 at 1:53am
@Auturgy I understand  - as this is a DIY forum: it is definitely possible to build your own system running free software. But I can ensure you that is not "easy to do" for everyone. What we offer, is system that works out-of-the-box and don't require a steep time and energy investment to roll out your own DIY solution.
Regarding latency: the typical end-to-end latency is a bit less than 150ms. As of "maximum latency" - I can't really tell you. Worst case might be: a 2.5G network can add up 300ms to this compared to an LTE nework. Also if you decide to fly a drone on the other side of the globe, speed-of-light limitations and general network delay will add up.
Comment by SkyDrone.aero on April 23, 2017 at 1:56am
@HeinduPlessis Yes, the system will automatically fall back to 3G or even GPRS/EDGE as it dynamically adapts the video parameters to the available bandwidth. So basically anywhere with cell data coverage will work.
Comment by John Arne Birkeland on April 23, 2017 at 4:22am
It's kinda weird having a 'unlimited' range video system that is cheaper then current short range digital systems. But I guess when piggybacking the existing LTE technology for transmission, you get reduced cost.
The system is cool, but for many the LTE part is more of a detractor. Depending on where in the world you are, it can be very costly to operate so it is mostly suited for commercial operations. But since legally we are still limited to VLOS range, we cannon use the potential of this system (catch-22).
Which brings me back to cost. Ironically if you could make a direct link system with medium range in the same price class it would probably sell much better. For example the $500 Connex short range FPV racing system is selling like hot cakes.
Comment
