As part of my plans to make a balloon-launched, return-to-launch UAV glider, I was looking out for a HD video camera that I could use in a typical fuselage installation. I chose to invest my hard-earned into the Drift HD170 mostly because I figured the rotating lens meant that it was probably separate from the main processor board. Only purchase and disassembly would find out...!
So, here's the full teardown and inspection of the device
The basic unit weighs 138g according the Drift, but stripped to this level it comes in at 58-60g, SD card included. The standard battery weighs 26g, but I intend to power the device from a central on-board battery pack, noise notwithstanding.
I plan on using the Skyfun as my airframe, so keeping the centre-of-gravity under control is my main priority. This will be mounted in the nose of the airframe, so losing every possible gram is important to me, but damn that lens is still pretty weighty! (about 30g of the 58g total!)
The Drift HD170 has a HD output via component cables. How are you doing composite output to a video transmitter?
The GoPro has composite output, but what about the Drift HD170?
Robert -
I took that picture with the Drift HD170 but I did not have it set up for transmitting video. We have been doing some testing with output though and as I learn more I will certainly share. We have thought about interrupting
the signal to the display as a possibility. How do you like the ImmersionRC transmitter?
Thanks for all the responses so far. I hope you find the teardown useful for your projects.
@Mike, I'll have to do another blog post to describe what I want to do - much theory and digital paper at the moment though, with baby steps.
@Hamish - thanks for the links! I think I've visited them before in my web-trawl. Art Vanden Berg's work is as impressive as it is inspirational. I'm slightly awed by the date that he did this - truly a pioneer!
@Robert Beatty - No, I haven't got it running as an FPV camera. I probably caused confusion by describing it as a POV camera in this context, which is how the camera industry seem to label it. I guess it must be possible to use it as a webcam-over-USB, but currently the firmware doesn't support it. Perhaps we can suggest to Drift that it develop this as a future firmware update? My plans don't include any FPV requirement though
Thats brilliant quality!
And Andrew, I'm hoping to do exactly what you are! You should check out the http://ukhas.org.uk/ community if you haven't already, it's UK based but there was a canadian on the IRC who has already done this a few years ago. He had a pretty simple autopilot and a 35mm camera on board! Old skool. Looks like hes making a new one too.
