TINY RTK : The world smallest precision GPS ... and the cheapest
Ultra precise positioning at low cost and reduced form factor.
We just release TINY RTK, the world smallest RTK GPS based on u-blox NEO-M8P.
Size: 23.5 x 24.5 mm
Key features
  • Centimeter‑level GNSS positioning for mass market, based on U-Blox M8P
  • Integrated Real Time Kinematics (RTK) for fast time‑to‑market
  • Smallest, lightest, and best energy‑efficient RTK module
  • Receiver type: 72-channel GPS L1 , GLONASS L1, BeiDou B1, GALILEO E1
  • Nav. update rate: up to 8 Hz
  • Position accuracy: 2.5 cm
  • Connectors: SMA, USB, JST-GH
  • Data link: whatever can be connected to a UART : Bluetooth, 433-868-915 MHz radio link, XBee, WiFi...
We've decided to launch an INDIEGOGO campaign to lower chip prices by ordering mass.
If you're interested by precision GNSS and want a Plug&Play solution at an incredible price ... TINY RTK is designed for you
Go To TINY RTK campaign
We'll post regular informations about TINY RTK during the campaign. We're also available for answering your questions, do not hesitate.
Comment by Rnold on September 12, 2016 at 11:09am
Interesting. What is its weight?
Comment by DROTEK on September 12, 2016 at 11:23am
Weight : 5g
Comment by Taras Rafa on September 12, 2016 at 12:33pm
1) If the "rover" station is attached to the drone, how far it can fly from the ground base station (assuming the data link can reach) without losing precision?
2) how well your solution can survive a GPS spoofing or jamming attack?
Comment by Rob_Lefebvre on September 12, 2016 at 12:36pm
Great work!  Can't wait to see this become widely available.
Would be even better if we can figure out a way to use only a single data-link for the RTK and the UAV telemetry.
Comment by Brian on September 12, 2016 at 12:48pm
@Rob_Lefebvre:  Sharing a data-link should be just a matter of software I would think, and it makes sense, since the two data streams are flowing in opposite directions.
@DROTEK: Why not integrate it with the antenna and add a mag.  Is this really anything more than just an M8P soldered onto a board with connectors?
Comment by Paul Meier on September 12, 2016 at 1:02pm
How does it work without a processor like Edison?
Comment by Brian on September 12, 2016 at 1:05pm
The M8P has the processor built-in.  It does all the calculation internal to the module.
Comment by Paul Meier on September 12, 2016 at 1:17pm
Merci Brian
Comment by KUJayhawk on September 12, 2016 at 1:22pm
Do you have a DJI solution?
Comment by RPM on September 12, 2016 at 1:28pm
This is awesome, congrats on being the first (that I know of) to get it in usable form. I assume ublox has their own processing algorithm? What are the advantages over similar boards using RTKlib? Other than weight.
Comment
