Following up on the success of my relay low battery warning leds I have expanded that code to include a complete lightshow and to be compatible with the newest ACM codes (2.1.1) and the APM1 hardware. APM2 hardware MAY work, but I don't have APM2 at this time, so no guarantees.
Credits to Bill Sanford and Max Levine whose work has been an inspiration and a basis for these leds.
1) Software side :
By using the agmatthews userhooks it is now much simpler to upgrade to a new firmware without having to change the code each time. You just have to copy 2 files and change setting in the APM_config.h. The needed files AND my config.h file (for version 2.1.1r5) are in the following file : U4eake_showleds.zip
Updated files for ArduCopter 2.5 (compile with arduino1.0 relax patch) : u4-showleds.zip These still work for ArduCopter 2.5.3.
Update files for ArduCopter 2.6 : Showleds_ACM2.6.zip Because motors were put in a library, every motor_armed in the showleds code had to be modified to motors.armed(). Also you have to put
#define COPTER_LEDS 0
into your APM_Config.h file to disable the new copterleds, which are enabled by default.
You need to copy the usercode.pde and the usercode.h files into your arducopter directory (overwriting the files already there) and add the settings below to your APM_config.h. DO NOT just copy my APM_config.h, it is only included as an example to clarify the settings.
#define MOTOR_LEDS 0 // 0 = off, 1 = on
#define SHOW_LEDS 1 // set to 1 to enable AN7-AN15 controlled led lightshow
#define RELAY_LEDS 0 // set to 1 to use the old relay led low battery warning#define COPTER_LEDS 0
#define BATTERY_EVENT ENABLED
#define LOW_VOLTAGE 9.9
#define MID_VOLTAGE 10.6
#define VOLT_DIV_RATIO 3.33#define INPUT_VOLTAGE 5.26
Also uncomment the 50hz agmatthews userhook and the mediumloop userhook (remove the // in front of it) so it looks like this :
#define USERHOOK_50HZLOOP userhook_50Hz();
#define USERHOOK_MEDIUMLOOP userhook_MediumLoop();
The voltages can be adjusted to match your desires. If you have a 4S battery for example, you should put higher values, like 13.2V for the LOW_VOLTAGE. INPUT_VOLTAGE is the voltage that goes into the APM (usually the voltage from you ubec). VOLT_DIV_RATIO is an calibration value that you can adjust so that your reported battery voltage corresponds to the real battery voltage.
After compiling the code with arduino and uploading it to the APM board, you also need to set battery monitoring to option 3 : battery volts
That's it for the software modifications if you have a hexa or are happy with the patterns as they are ! On a quad or octo you may want to adjust the patterns a bit, but I'll explain that further down this blog (see Adjusting Patterns).
The code and blink patterns are optimised for use on my hexa (6 leds strips on the arms + 2 spare ones).
The leds will go on when motors are armed and out when disarmed. During flight, different flashing patterns can be selected with Ch7. The other use of Ch7 is not affected, so you can still use it for simple or recording waypoints. The leds will flash with the last pattern in this file when ch7 is high (recording waypoint or simple)
When battery gets below the first threshold (MID_VOLTAGE = 10.6V), the ledshow is overridden and the leds will flash with following pattern : led 1,3,5 on/off and led 2,4,6 off/on. So if the first ones are off, the others are on and vice versa.
When second threshold (LOW_VOLTAGE)is reached (9.9V) the leds will flash quicker.
2) Hardware :
The code uses the AN8 tot AN15 analog ports (portK) on the oilpan of APM1. In the picture you can see them labelled AN0-AN15. AN8 to AN15 are the ones on the right (4x2 pins)
You can either connect 1 led directly to each port (the ports can supply 40mA current) or you can use a ULN2803 darlington transistor chip to drive the leds according to the following shedule (thx to Max Levine for this schematic) :
This shedule is for a quad and uses a ULN2003. The ULN2803 has 8 ports instead of 7 and if I remember correctly it can supply a little more currrent (500mA per port). A typical hobbyking 12V ledstrip of 1m (60 leds) consumes about 300mA, so normally you should be able to hang 1m of ledstrip on each of the 8 ports. That should be plenty !!
You can get the ULN2803 in your local electronics shop or online here : Canadadrones - ULN2803
The darlington chip lets each input control the output directly across on the other side of the chip. So nr1 in the picture above, controls output 16, Nr 2 controls output 15 and so on. If you look at the pinout picture of the oilpan, you'll see that nr 1 is connected to AN8 and nr2 is connected to AN10, so AN8 in the pictures above controls the red leds, and AN10 controls the green leds. Get it ? ;-)
After the brainsurgery it will look something like this :
Now you just have to put a heatshrink over the ULN2803 chip and tuck all the wires away nicely.
CAREFULL : in the picture above I had soldered the wires to the wrong ports (side of the compass). That's what you get when working on your copter till 4 in the morning... It took me a day to figure out why my leds didn't work as expected. So you have to solder your wires on the OTHER SIDE (side of the usb connector). I didn't have a picture of when I soldered it right.
Finally you'll also have to set up your board for battery monitoring (option 3 : total voltage) by soldering the voltage dividers and connecting battery voltage to AN0, which is explained in the wiki here : Voltage sensors on APM1
3) Adjusting the blinking patterns
First you'll have to understand a little about bitmath in arduino : http://www.arduino.cc/playground/Code/BitMath
To save processor cycles I've opted to drive the portK of the atmega1280 using direct portmanipulation.
If the above all sounds too complicated : here's the simple explanation.
In the usercode you'll often find something like PORTK = B00101010; This instruction actually turns leds on and off. 0 means off and 1 means on. Each number turns 1 port off or on, and the first number after B turns port AN15 on. So the ports are B-AN15-AN14-AN13-AN12-AN11-AN10-AN9-AN8 of shorter written : BAN15...AN8
If you would now like to turn the red leds on and the others off in the picture above, this would be PORTK = B00000001; (turns AN8 on, and AN8 is connect to nr1 on the darlington, which turns on red leds)
If you wanna turn the 2 blue ledstrips on and the others off it would be PORTK = B01010000; (ports AN12 and AN14 on, which are connect through the darlington to blue leds)
All 4 strips on would be PortK = B01010101;
Ofcourse for hexa's and octo's this depends on which AN port you have soldered to which nr on the ULN2803.
Now we can turn leds on and off, but they still don't blink or "rotate". For the blinking a counter is used and depending on the counter, leds are switched on and off. The counter runs in the 10hz or 50hz loop, so you can time the blinking. If counter =5 when in the 10hz loop will correspond to half a second.
For "rotating" arms I use the bitmath again, more precisely the bitshift operators << and >>. These simple shift all bit a few places. so 00000001 << 1 becomes 00000010. The 1 shifts 1 place. By now you understood that this is an easy way to make the leds "rotate". Just shift the B00000001 1 place each loop cycle and your 'on' leds will shift an arm each cycle, making them look asif they rotate.
4) TO DO
On the 8 port ULN2803 there are still 2 ports left unused on my hexa. I'm planning to use those to replicate the gps status light and maybe a failsafe warning light. I've also thought about using them to drive leds in the form of a smiley :-) Other ideas are always welcome !
I'm using the relay now to ignite fireworks on the hexa. But that's a story for another blog ;-)
That's about all I can think of telling you, and by now my fingers are tired and my brain is mushy.
I hope you enjoy these leds and don't scare too many people with your new UFO ;-) Feel free to ask questions in the comments below if something is not clear.
Ow, and ofcourse I assume that you know what you're doing if you solder on your board. I take NO responsability if something goes wrong and you break it ! Do this at your own risk !
U4
Hi Kevin,
Not bad at all for "not being a programmer" ;-)
If you share the final code I will also use it on my new AC3.01 quad, and I'm sure many other will too. If you make a new blog about it I'll modify my post with a link to yours
Thx for the port !
The direct port manipulations I use in showleds uses VERY little cpu resources. They are set in 1 or 2 clockcycles. the if-then statements also use only a few clockcycles, which is neglectable compared to the other stuff the processor has to do. Furthermore there is only 1 option (fast rotating arms) that uses the 50Hz loop (you could comment that one out), all the others only use the 10hz loop.
So I think it is UNlikely that there will be timing problems, but ofc the devs wanna play it safe and not get any complaints about strange issues.
It is true that copterLEDs used to cause some timingproblems, but that was because it doesn't use direct port manipulation, it uses DigitalWrite() to set the ports, which is a function that consumes rather a lot of processorcycles, because it does a some checks to ensure compatibility with all arduino boards.
Hi Kevin,
Sounds like your well on your way. I too have recently assembled me a AC3.0 quad and I'll probably put some leds on it soon. That may get me interested in porting my code to AC3.
Anyway, what you're saying makes sense.
First I would make sure that the AN0-8 are really connected to portF by changing 1 of them in the 1hz loop for example and connecting a single led and resistor to it.
Now if I recall correctly, I once forgot to do the DDRK=11111111 statement and the whole ledshow didn't work, (leds only went on VERY faintly) cause the ports were not configured as output.. I believe configuring a port as output just turns the internal pull-up resistor off, so the port can supply some power (40mA per port, 200mA max in total). It means you probably won't damage anything if the ports stay configured as inputs (if you shortcircuit a port that's configured as output, you may burn it) , BUT they probably will affect measurments of any attached sensors. So just leaving the pins configured as inputs probably won't do it.
However, there is a bitmath trick to only change certain ports and leave the rest in the state they were in. It was something with the AND and XOR operators or something. Check the bitmath part on the arduino website, it was explained there how to do it, but I didn't bother getting to the bottom of it for my code cause I didn't need it. (nothing else attached to portK on my old APM1.)
Gustavo, search the forum for Copterleds and you should find some usefull info. Also you can look in the Leds.pde source file, there is a comment section where the basics are explained.
Triantafillos, I think the circuit will also work with 5V from a bec and 5V led strips.
Could somebody clarify please ? It seams to me that some functionality has already been included on the firmware but the manual is not reflecting this changes.
Many thanks
What a nice new option!
I'm wondering where the equivalent connectors (1,2,3,4) are located on the APM 2.5?
Another idea........... is there a way to route the signal leds out from on the (APM2.5)board to external leds?
Regards :)
Good point. I'll give it a shot. I already have a spare anyway.
Robert, looking at the schematic of the ULN I don't see why it wouldn't be able to sink current from different voltage sources. Haven't tried it though. If you try and you fail, it'll only cost you $1.
U4: Question, do you know if the ULN2803 can sink current from different voltage sources? Can I have some LED's supplied with 12V, and some with 6V? I don't see why not as it's just providing a ground path?
Jonathan, I haven't read through everything so I'm not quite sure what I'm doing, but I dug up some old Devlist emails I wrote back in the day, and this may help you?
This gets more confusing...
#if CONFIG_APM_HARDWARE == APM_HARDWARE_APM2
#define COPTER_LED_1 AN4 // Motor or Aux LED
#define COPTER_LED_2 AN5 // Motor LED or Beeper
#define COPTER_LED_3 AN6 // Motor or GPS LED
#define COPTER_LED_4 AN7 // Motor LED
#define COPTER_LED_5 AN8 // Motor LED
#define COPTER_LED_6 AN9 // Motor LED
#define COPTER_LED_7 AN10 // Motor LED
#define COPTER_LED_8 AN11 // Motor LED
#elif CONFIG_APM_HARDWARE == APM_HARDWARE_APM1
#define COPTER_LED_1 AN8 // Motor or Aux LED
#define COPTER_LED_2 AN9 // Motor LED
#define COPTER_LED_3 AN10 // Motor or GPS LED
#define COPTER_LED_4 AN11 // Motor LED
#define COPTER_LED_5 AN12 // Motor LED
#define COPTER_LED_6 AN13 // Motor LED
#define COPTER_LED_7 AN14 // Motor LED
#define COPTER_LED_8 AN15 // Motor LED
#endif
#define AN0 54 // resistor, vdiv use, divider 1 closest to relay
#define AN1 55 // resistor, vdiv use, divider 2
#define AN2 56 // resistor, vdiv use, divider 3
#define AN3 57 // resistor, vdiv use, divider 4 closest to SW2
#define AN4 58 // direct GPIO pin, default as analog input, next to SW2 switch
#define AN5 59 // direct GPIO pin, default as analog input, next to SW2 switch
#define AN6 60 // direct GPIO pin, default as analog input, close to Pressure sensor, Expansion Ports
#define AN7 61 // direct GPIO pin, default as analog input, close to Pressure sensor, Expansion Ports
#define AN8 62 // NC
#define AN9 63 // NC
#define AN10 64 // NC
#define AN11 65 // NC
#define AN12 66 // NC
#define AN13 67 // NC
#define AN14 68 // NC
#define AN15 69 // NC
Hi Jonathan, I know the feeling of thinking you have it, starting on the board and then running into issues. That's when you have to push through and ask specific questions and/or spend lots of time figuring it out, gambling and testing :-)
So ready, here goes.
1) The APM has it's ground from whatever powers it. It's not shown in the schematic cause it's not really relevant to what we are doing. The apm is supposed to be powered and have a ground, else nothing will work. The APM is not even completely shown for that matter. I guess to be complete you could draw a black line from the APM board to the - of the battery with a bec or esc in between, but it would complicate the drawing without adding much info.
The APM pins AN8-AN15 put out 0 volts when off and 5V when on and can provide max 40mA current. Enough for a single 5V led, not good enough for a 20 led strip of 12V leds, so that's why we need the ULN. It acts as a relay. When the ULN sees 5V on its pin 1, it will connect pin 16 to pin 8 (ground) thus turning the red leds on. It might be good to look up the datasheet of the ULN to further understand its working.
2) This is more complicated and took me a few days to figure out on my APM1 too... PortK is the name of 8 pins (PK0 - PK7) on the ATmega1280 processor (the large black chip). I think they are the same on the ATmega2560. The datasheet of the atmega will show that. These are the ports the atmega processor knows about, these are his ports. It doesn't know AN ports, AN is what the ardupilot board designer decided to call them cause they are Analog ports.
So now you have to find out to which pins on the board these little chip pins are connected. Or better, you have to find out to which little chip pins the AN ports of the APM2 connect. Then you look up in the Atmega datasheet which port that is and then you change the instruction accordingly. So if you find that APM2 ports are connected to chip pins PJ0-PJ7 then you use the instruction PORTJ=B00000000 instead of PORTK.
I also like nightflying (although forbidden in my country). I have 2 spare ports on the ULN and was thinking of making one light up a smiley face, and one a sad face :-) and :-(
Hope this gets you going a bit !
Greets, U4
1
2
3
4
5
of 6 Next
