3689596248?profile=original
Dear Friends,
in last month of this year our team work a lot on new electronic boards :
  • VR Micro Brain 5
  • VR Brain 5
  • VR GPS Ublox LEA6.
  • VR Telemetry Module.
Our products have the feature of being based on the original design and not be mere clones, with a research and development team ready to meet the demands and needs of users more evolved.
3689596310?profile=original
VR Brain 5 Micro
The VRBrain Micro is a board of the new 5.x series of extremely small dimensions and is based on the powerful micro processor STM32F4 to 168 MHz , the operating system supports Nuttx as the PX4  and Pixhawk  and It compatible with the APM firmware Copter , Plane and Rover.
The Brain VR Micro is very small and lightweight only 10 grams in weight and 3.7 x 3.7 cm wide. Ideal for setting up of small and micro  sized drones as the frame AV250 .
Supports GPS and magnetometers external standard which it shares with the standard vr brain and allows the controller to provide automatic features as stabilize ,  return to the home , hybrid loiter auto take off and landing .
The board  able to handle up to 12 inputs on sbus receiver and 6  input on  PWM standard receiver , 8 PWM outputs for connecting ESC or Servo .
The source code of the project and ' available on the official repository and DIY Drone and ' ongoing integration of automatic features to APM Planner firmware upload directed, via bootloader.
These are the specifications :
  • CPU STM32F4 VR OS based on NuttX kernel 7.1
  • 1 I2C EEPROM  for parameter storage.
  • IMU MPU6000 SPI.
  • MSIC Barometer 10 cm resolution.
  • 8 PPM Radio RC Input .
  • 8 PWM ESC - SERVO Output.
  • 1 SBUS Radio Input compatible with Futaba SBUS and Spektrum ,too
  • 1 SBUS Servo Output.
  • SD Card Reader until 64 Gbyte.
  • 1 RGB LED
  • 2 LED Output
  • 1 Buzzer Output
  • On board telemetry module availabe at 433 / 868 mhz. (option)
  • connector for external 3DR/VR GPS + MAGNETOMETER
  • dimension : 3.7 x 3.7  hole 3.2 x 3.2 .
  • weight : 10 gr
Status : First Fly done all work fine available for Pre Order.
VRBrain 5
3689571223?profile=original
3689596331?profile=original
The VRBrain  5 is  the evolution of the 4th revision board, at an architectural level remains very similar to the previous version of Flight Control Board having demonstrated excellent reliability and robustness.
The card features the latest generation processor STM32F4 OS 7.1 Nuttx This card was created with the aim to implement greater redundancy than the earlier and allow the autopilot to integrate into a  distributed wifi network environment .
The board allows you to support 2 IMU sensor based on MPU6000 chip , up to 3 magnetometers and two GPS . In addition to the bus for redundancy and imu ' present an additional bus that allows you to add devices bluetooth or wifi network to interconnect directly to the drone PAD and Smartphone , or to the standards network infrastructure  .
It 's  also available  CAN bus for high-speed interconnection of optional devices.
The board revision 5 have a slot for  use  SD card that allows you to save the  flight logs and make them available online for integration with portals log flight management .
The card bootloader  allows the card to be updated directly from mission planner or compatible CGS applications.
These are the basic specs :
  • 1 I2C EEPROM  e FRAM for parameter storage.
  • 2 IMU MPU6000 SPI , second imu option.
  • MSIC Barometer 10 cm resolution .
  • 1 MSIC Barometer  option 2th barometer on external  imu.
  • 1 RGB LED
  • 2 LED Output
  • 1 Buzzer Output
  • CAN BUS for interconnect option module
  • 1 connector for  VR telemetry module availabe at 433 / 868 mhz. (option)
  • 2 connector for external 3DR/VR GPS + MAGNETOMETER (option)
  • weight : 23 gr
  • enclosure available.
 Status : pre flight check done , all is good , in production .
Available in pre order .
VR GPS
3689584979?profile=original
VR GPS Ublox Lea 6H with HMC5983 Magnetometer
First Virtualrobotix GPS engine using Ublox LEA-6H receiver.
This is a 50-channel high sensitive engine that boasts a Time-To-First-Fix (TTFF) of less than 1 second.
Also provide a rechargeable backup battery to improve warm start.
The dedicated acquisition engine, with over 2 million correlators, is capable of massive parallel time/frequency space searches, enabling it to find satellites instantly.
Innovative design and technology suppresses interference sources and mitigates multipath effects, giving LEA-6H GPS receivers excellent navigation performance even in the most challenging environments.
Virtualrobotix GPS uses an high efficient low noise amplifier to improve antenna signal (19dB) and a SAW filter to select GPS frequencies (see graph below).
3689584848?profile=original
It also mounting an ultimate 3-axis digital compass, with selectable interface SPI or I2C (HMC5983).
This one is an high speed (220Hz output) and high resolution (2 milli-gauss) magnetometer.
Features and Specifications:
  • ublox LEA-6H module
  • 3,3V or 5V Inputs, with low noise 3.3V regulator.
  • 5 Hz update rate
  • Rechargeable 3V lithium backup battery for high efficient warm start
  • Panasonic Low Noise Amplifier for antenna signal with high gain (19dB)
  • EPCOS SAW high quality low-loss RF filter for GPS application
  • 25 x 25 x 4 mm ceramic patch antenna
  • Dedicated I2C EEPROM for receiver configuration storage
  • High resolution compass (2 milli-gauss) and high speed (2 milli-gauss)
  • Power and fix indicator LEDs
  • ArduPilot Mega compatible 6-pin JST connector
  • Exposed pads for simple soldering connection.
  • I2c / SPI HMC5983 magnetometer .
  • 2 ttl tx-rx ser connection.
  • 38 x 38 x 8.5 mm total size, 18 grams.
Status : all it's ok a lot of flight without problem , in production , ready  for pre order.
Some example from log collected in first test VRX GPS is red Line 3DR is blu
3689585019?profile=original
VR Link (telemetry Module) - micro - standard - advanced OSD - base station .
3689596289?profile=original
3689596402?profile=original
In addition to the autopilot systems in our laboratories have been developing a telemetry system simple , modular and advanced compared to what's available on the market and compatible with the 1.0 mavlink protocol.
We chose to mantain compatibility with the modules 3DR , but we have worked to expand its functionality.
Micro version :
The micro version it's an add on to the micro brain that allows you to add easily and efficiently support wireless connectivity directly onboard .
The module ' based on the micro SILAB 1000 and it' core normally available .
Standard version:
The standard version is a standard kit with a radio that will allow the connection from the drone to the ground, the main peculiarity of the standard version is that can work independently by simply feeding it through a usb battery pack or a small lipo .
On the ground the module replicates the light and sound of the buzzer's drone.
This feature allows you to detect any alarm signal even if the light on the drone is not ' perfectly visible.
The module on board the drone has available an RGB LED and a speaker very powerful signal that allows you to see and hear even at a considerable distance of the drone .
These new modules using the communication protocol mavlink and therefore are compatible with any drone supports this protocol : VRBrain 4.x and 5.x - APM 2.x, PX4 , Pixhawk , Autoquad etc.
With this feature easily solve a problem that often prevents you from realizing anomalies on board the aircraft such as the loss of the GPS signal , the abrupt decrease in battery level or the sudden lack of the radio signal that activates the failsafe .
Osd advanced version :
On board of drone  can integrate the function  osd simply adding a module dedicated on  the telemetry module . This configuration allows you to add the image coming from the analog video  FPV  camera as overlay of standard fly information as :
artificial horizon, altitude , distance from home , flight mode , battery level , etc. etc..
Status : hardware ok , working progress on first revision of firmware for standard and advanced revision.
We are ready for the worldwide market if you need more info on price ,  pre order , or you want to became a member of our distributor , support and developer team contact : info@virtualrobotix.com
original blog post :
http://www.virtualrobotix.com/profiles/blogs/virtualrobotix-electronic-boards-roadmap-prossime-uscite-dei-nuov
Best
Roberto
  • Hello Roberto,
    I have a Micro Brain Ordered which cable do I need?
    Greeting Helmut
  • @Roberto
    I have a micro brain on preorder.
    Is it possible to use an input to monitor an adapted APM power module or similar to monitor current and calculate battery usage as with the APM?
    Cheers,
    Stu
    @Stuart,
    The onboard bec is only until 3S , it's originally developed for small drone for big one is better to use external bec .
    For 4-6S is better to use VR telemetry module option that integrate a good 3A bec.
    best
    Roberto
    @Micha ,
    now we are in production and pre order only with VR Micro Brain v5.
    The brain will be available in 1 week
  • I meant BEC, autocorrect on my phone playing games! :)
  • Thanks Roberto, what is the input voltage range for the bed on the brain 5?
  • The 4 to 5 week projection, is that for the brain 5 or for the microbrain?
    @ Stuart Brookes
    the micro don't have onboard the sensor redudancy , can bus and integrated bec.
    The power of micro is the same , but for redudancy is possible use different approach as use two micro togheter with a vr cluster that is a special module that now is in wip for hot swap switch on two flight control board. Another difference is precence of FRAM instead of EEPROM on standard vrbrain 5
    best
    Roberto
  • Perfetto, grazie!
    @Joshua Ott
    yes is possible you can mount the osd module on board or on ground the modue recive the mavlink protcol and add overlay on local video.
    best
    Roberto
